ON the motorola Surfboard SBG900 wireless.All ports blocked when tested. How do I unblock any port?. Did the port forwarding thing. Nothing works Using Chatter Comm.for IS provider.
(Is the SPI Firewall that you are refering to the Cable modem firewall?) Firewalls on Cable modem and Win XP are disable.(Is the SPI Firewall that you are refering to the Cable modem firewall?) Firewalls on Cable modem and Win XP are disable.
You can't post conmments that contain an email address.
MagicJack uses port 5060 & 5070 UDP. so go into your router and select port forwarding or applications something along those lines and insert the correct ports into the configuration. it should be pretty self explanatory. i'm not familiar with this particular model of router. if you need instructions they can be found here: http://broadband.motorola.com/noflash/customer_docs/user_guides/506705-001.pdf if however your ISP is blocking the use of magic jack there isn't alot you can do about it
For VPN, you will have to open specific ports in your router . See this link..for what ports have to be opened.
http://www.speedguide.net/faq_in_q.php?category=102&qid=163
To open the ports, you have to go to the webinterface of the router .
Hope this helps
Thanks
Ranjit
