Cars & Trucks Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MPV 2002. Black particles come out from air vents
I have a MPV 2002. Heat comes out from the front air vents, np, but also these black particles. No burn smell... help
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 205 Answers
  • Posted on Jan 06, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
205
Questions
Helped
60706
Points
621
I get the feeling this is the first time you've used the heater? Its probably accumulated dust. As long as you don't get a burning smell or smell exhaust fumes you should be ok after a few hours use.
With the unit on heat the front vents blow heat but the rear vents only blow cold air
are you talking about the overhead vents? They only recirculate air without the a/c on.
1helpful
2answers
Bad smell coming from vents in my 2002 silhouette
did you change your hepa filter? Buy ozium and spray in your vents.
1helpful
2answers
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
When I turn on the heat in my 2004 mazda mpvicon1.png the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
Warm are transfers to front of car but cold air
door for the evaporator/heater core is malfunctioning. common thing for the pins on the door to break off.
Front vents will not work
If they are stuck on defrost,then the problem is a little vaccum line that comes through the firewall as all the climate controls are vaccum controlled,so look for a small green or black plastic line unhooked.
8helpful
3answers
2002 Ford Expedition Climate Control System
you have a loss of vacuum. There is a small diameter black plastic tube from the engine compartment that feeds the climate controls. Check at back of control head, or there is a plastic connector under dash were other color tubes join to operate the other actuators of the system the black tube must have vacuum when engine is running. check under hood the black tube is spliced. separate the tube and check for vacuum The tube enters the firewall near the heater hoses.
Cold air coming from rear vent of 2000 mazda mpv
Your ventilation shutter is not closing properly.
1helpful
Radiator drain plug
Just recently found this on my MPV. get on your back and slide just under the front of the van. just behind the bumper you'll see several holes about 3/4" to 1" diameter. there is one located more toward the driver side. there is a large black Phillips head screw. this should be the drain for the coolant/antifreeze. if you look inside under the hood, or through some of the other holes, you should be able to see where this connects to the radiator. hope that helps.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
