Question about Motorola Mobility RAZR V3
V3 Mototola Razr Phone Freezes and charger won't work
I have a work phone that I desperately need to fix. I don't mind getting it replaced, but I really need the information that is in the broken phone.
I have a Motorola V# Razr I got about a year ago. I would be the first to admit that I am not the most gentle user when it comes to small electronics. When I plugged my phone into my wall charger today it initially said "unauthorized charger" and then it said "charging" after some wiggling. So I walked away and about ten minutes later I heard the phone beep to signify that I had just plugged in the charger. After some examination I realized that my phone was somehow freezing and then resetting every couple of minutes or so without being revoked. It doesn't turn completely off just freezes and then returns to the main screen. If I open it to use it, it will allow me to make a couple of key presses before it freezes and resets. It hasn't been getting any incoming calls and it will let me call out only before it resets which isn't long enough to even hear a ring on the other end. I don't know what to do. All I want to do is get my contact information out of it so that I can move on with my life. Any suggestions?????
  • 3 more comments
  • V3vixen Feb 21, 2008
    2 weeks ago my V3 that I've had for about 1.5 years gave me the "unauthorized charger" message when I plugged it into my "authorized" Motorola wall charger that came with the phone from Verizon originally. I was able to unplug and plug back in and it charged. The next time I tried to charge, I got the same message but unplugging and replugging the charger did not work. I then tried to charge the phone using my Motorola charger purchased from Verizon that I had also been using just fine since buying the RAZR and it charged for me. The next time I tried to charge first with the wall unit and then the car charger - neither would charge it and again the same message. I called Verizon today and the only recommendation I got was to remove and then replace the battery (basically a reboot) then dial 228 send and option 1 to reset. The CS person said this works 9 times out of 10. I guess I was 10 - it didn't work. It's my only phone so I Googled trying to find answers. The only thing I've come up with is to go back to plugging/unplugging and wiggling. I don't think this is very good for the phone but I do have it charging again. Does anyone have any better ideas? Sounds like it's time for a recall to me!
    Thanks.
  • slim31 Mar 18, 2008
    same exact problem except my phone is the motorola krazer. I need a quick fix cause im not keeping the phone for long.
    The only thing i can do is plug it up but nothing is working, at all.
  • CodeLock Oct 15, 2008
    My phone has the same problem.
    Make: Motorola
    Model: V3m
    Features: Camera phone, EVDO connection. (Music, video, etc.)
    Carrier: Verizon
    Problem:
    It will turn on, then 3 seconds after I get the "Enter Unlock Code" screen, it will freeze and then reset to the same screen. I get about 3 seconds to punch numbers in, but it will freeze and reset, so I can't even *228 to update the software. I have setup security to lock the phone when resetting/rebooting.
    The Verizon CS I talked to told me that it was the first time she heard of a power cycle problem like that, and told me to take out the batter (I did that), reset (I did that too), and try to dial *228 (I can't even dial). So the last solution was to take it in to get it replaced.
    It all started when the battery started draining very quickly without much usage at all, just on standby.
    Then it began to just drain at an unusually short amount of time. Now, I know that phones drain quickly when I enter an elevator or go inside a concrete building, etc., but this was ridiculous - 2 hours - and completely drained! Without active use! In plain daylight, outside, under the sun.
    Then my phone would occasionally reset in the middle of the day, asking me to enter the Unlock Code.(It's the security setting I have on.) I thought it was strange at first, but it started becoming more frequent. Then I thought maybe it was just a bad reception area that I was in.
    My guess is that:
    1. There's a software problem,
    2. There's a virus,
    3. Battery is bad,
    4. Connection to the battery is bad,(Terminal or internal)
    5. Connection to the charger is bad, (Terminal or socket)
    6. Charger itself maybe bad,(Maybe inside the adapter or the line itself)
    7. I need a new phone.
    However, I would like to get all my phone numbers out of my phone, since I don't have them written down anywhere. I have other messages, pictures and songs/music in there that I don't have a copy of anywhere else, so this is really bad. I'm taking it in to a service dealer tomorrow to see if they can figure it out, if not - at least they may be able to do a data transfer for me - as far as the phone book/contact list is concerned, but as for other data, I don't know.
  • j peterson Nov 11, 2008
    I have a Motorola Razr V3c. I got about two years ago. i am in an extented network area. my phone is freezing and then resetting every few of seconds. It doesn't turn completely off just freezes and then returns to the main screen. If I open it to use it, it will allow me to make a couple of key presses before it freezes and resets. It hasn't been getting any incoming calls and it will let me call out only before it resets which isn't long enough to even hear a ring on the other end. i noticed that when you can actually use the keypad, the keypad lights up and the screen darkens like when your battery save kicks in (also the battery symbol flashes and the no service symbol appears, when on the charger). then there will be a flash and the keypad lights go out, there is no signal (the battery status symbol DISAPPEARS and the 1X appears, when on the charger), at this point the key pad and all the rest of the buttons are non responsive. a couple of seconds later the screen will brighten up for a few seconds (still not having a battery symbol and still having the 1X, when on the charger). then the keypad will light up and then the screen will get darker again (the battery symbol starts flashing, the 1X disappears, and the no service symbol appears again, when on the charger) at which point it will be responsive again. AND REPEAT. when not on the charger, the battery symbol continually stays on but the rest of the descriptions above stay the same. Any suggestions?????
  • Anonymous Nov 25, 2008
    my phone just went blank and the screen would not turn back on no more.
I pushed the charger in the phone as hard as i could and then rapped it in rubber bands. that has works so far
Posted on Oct 14, 2008
I have searched and read all possible solutions. This is not a hardware problem. plugging and unplugging will not resolve the "unauthorized charger". My headset works when plug into the V3m mini USB port but plug a charger into that port and I receive the same old message "unauthorized charger". I read solutions such as replace the USB port or have it serviced. Sorry, those solutions are B.S. This is a software issue, no fix is available, considered old technology. Do your self the favor and give your RAZR a FUNERAL. and find a different carrier.
Posted on Jul 01, 2008
    Brigadier General:
  • 7,752 Answers
Unfortunately the phone needs to be reflash but this will delete all information on the phone.
So take the phone to a mobile service center and have that done.
Posted on Feb 05, 2008
How to unlock my phone v3 motorola cingular
ou can unlock your mototola v3 mobile from network lock using unlock code...Once you unlocked it you can use any gsm network sim card in your mobile at any country...I found an unlocking service at here www.unlocking4u.com and unlocked my mobile successfully.This is the online service which offer the code at reasonable cost...Through this can unlock your mobile easily...
Oct 08, 2011 | Motorola Mobility RAZR V3c Cellular Phone
When i try to open the inbox of my razr v3 the phone freezes and wont let me do anything but press the hang up button and return to the home screen. It does the same thing with my outbox, and quick text....
phone covers and broke off the top side off the screen volume control buttons and now it turns on but the screen is not working...V3 Razr's to my knowledge don't have changeable covers. Put on original ...
Aug 25, 2011 | Motorola Mobility RAZR V3
Razr v3 freezes when i go ton ext
I've heard it was a software glitch.
Who is your carrier?
Sep 22, 2009 | Motorola Mobility RAZR V3
My black razr phone will power on but freezes on the moto screen
Call your phone company. It's a software issue, they need to replace your phone or exchange it for a different one. I've had the same problem. Best of luck, sorry your having trouble!
Mar 19, 2009 | Motorola Mobility RAZR V3
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
Screen goes black and phone freezes.
Jessikah - take the phone and have the Flexcable replaced.
Captmartin53 - You need to reflash the phone's firmware for you.
Aug 19, 2008 | Motorola Mobility RAZR V3
Cell phone
I had a problem very similar to this with my Razr but my service was through Verizon. I took it into a Verizon store and they thought that a software upgrade would fix the problem. It didn't. Fortunately, the phone was still under warranty and they ended up replacing the phone.
Warranty on the Razr is one year.
Feb 11, 2008 | Motorola Mobility RAZR V3
Bottom line on Razr V3
First it was very thin phone, extra care needed. If you dont drop or step to that phone your be fine. And just wait for the replacement to come and take care of it.
Aug 04, 2007 | Motorola Mobility RAZR V3
Motorola RAZR won't charge
that happens mostly with third party chargers..you may want to explore the option of charging your phone using the PC and a USB cable...you may be required to download a software or driver for it ..along with eh motorola phone tool
Apr 30, 2007 | Motorola Mobility RAZR V3
Motorola Razr Screen all white.
what you can do is buy a connector kit from a mototola place and connect it with your computer, then you will be able to see all the numbers on your phone, you will have to maybe manualy transfer the numbers but at least you will have the numbers
Jan 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
1,085 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
