Konika 3135 copier putting dark areas all over copies.
Hi,just trying to fix above problem for a Buddhist monk friend.
  • wookienz Feb 06, 2008
    thanks very much guys! i have cleaned the platter and mirrors which made an improvement,but still grey and dark areas top & bottom,so have removed drum assm. and will have it serviced,your help is much appreciated! have a great week!
  • Anonymous May 11, 2010
    Can you be more specific with the problem?
    Are the marks consistent?
    Do they run vertically, or horizontally? (front to rear of the copy, or left to right)?
    It can be a number of things, especially given the age of that model.
  • 1,326 Answers
Your a little vag on the problem. The problem is most likely in the drum unit or fixing ass'y. If it Blutchs of toner, it most likely that the small little lip on the developer ass'y is full and needs to be cleaned out. It seats right below the mag roller of the developing ass'y. Or it could be the anti spill mylar under the drum cleaning blade. Need more info. to pin point.
Posted on Feb 05, 2008
6ya staff
SOURCE:
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konika minolta bizhub 350. When I try to Copy There is a message: "Pleaser Reposition Original". What does it mean? How can I fix it? The paper is checked (size).
BEFORE YOU PUT THE CHECK ON THE GLASS, SELECT THE PAPER DRAWER YOU WANT TO COPY ONTO, THEN PLACE THE CHECK ON THE GLASS, THE COPIER DOES NOT KNOW THAT SIZE
Aug 28, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
My copier puts out copies that have two dark stripes along the right side of the paper. What can I do to fix it. I've replace the ink cartridge and cleaned the glass. xc830
Usually its a leakage on the cartirdge . Ill be advising you to remove the cartridges adn used a clean paper make sure its clean .Clean also the area where you put the cartridge make sure its clean .Then return it back make sure its plugged in properly close the carrier and th cover try to print again in case nothing happens .Go to the settings look for clean cartridge ..
in case still the same thing look try again in case nothing happens asked for a cartridge replacement
May 26, 2011 | Office Equipment & Supplies
I have a Sharp AL-1655CS and when i make copies, the copies are really dark. For example, the white areas come out gray and dark. How can I fix this problem?
I would try a different toner cartridge or possibly a drum cartridge. Have you had the machine serviced at all? When?
Feb 14, 2011 | Sharp AL-1655CS Laser Printer
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Open Questions:
jasbo
jasbo
Ekse
Marvin
Marvin
