Question about Sharp AL-1642CS Copier
Sharp al-1642cs hi the problem i am experiencing has to do with feeding the document to be copied. when it is feed in the first part of the image does not copy. the laser unit doesnt seem to be moving all the way to the right to start scanning.
  • 2 more comments
  • chris palmer
    chris palmer Feb 07, 2008
    it goes to the home position just fine. i can copy if i put original on the bed but it wont if i feed in from the top. the scanner doesnt seem to be going all the way over to the right to scan documents that i feed from the top.
  • chris palmer
    chris palmer Feb 19, 2008
    i took the doc feeder apart to find a mis seated sensor. After reassemble thing seem to be OK.
  • RITZI Feb 20, 2008
    cómo conseguir un disco de intalación para Sharp AL-1642CS
  • chris palmer
    chris palmer Oct 20, 2008
    I disasembled the feed assy. and the sensor was out of position all set now
  • 66 Answers
If scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Posted on Feb 06, 2008
  • sohail anjum Feb 07, 2008
    it looks to me that feeder is not working . or the rigestrion is off. if you make 4 copy from the bed and all comes out ok than the proublem. is feeder. if one or two copy come out missing image than regtration clutch is bad.
I have the sharp al-1642CS and need to print ups full sheet labels for shipping. Tray 1 will not pick up the labels and jams. I can not get the sharp to print via the multi-tray when I send a job from my...
Will the tray not pick them up at all, or do they feed out about 2 inches? If they feed out of the tray and will not get past the curved area you need to open that door where the jam is and make the spring pressure on those springs on each side tighter. I kind of loop the bottom hook of the spring up into the rest of the spring to create more spring pressure on the rolls and then it should work.
May 19, 2010 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
L 1 flash alternately. Scan head is unlocked on the AL-1642CS.
L1 is the exposure lamp and mirror feed motor malfunctions code.Change the expo lamp therofuse or the mtors.
Dec 11, 2009 | Sharp AL-1642CS Copier
Sharp AL1642CS makes clicking sound when rollers turning
If you are in the US then go to sharpusa.com business copiers and locate dealers
Nov 21, 2009 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Lines on copys when i feed through top feeder
There is a small strip of glass under the feeder.Not the main glass, but look where the lamp is sittting in the start position.
You have something on that section of glass.
It may be very tiny, but that is what causes that. Best way I have found to get that clean is with some alcohol and just a plain piece of copy paper crumpled and used as your cleaning towel.
The reason it is there only when you copy through the feeder is this. When you copy off the glass, the lamp moves and scans the original end to end. So a spot is simply a spot.
When you run through the feeder, the lamp parks and the document passes over the lamp scanning that way. So any mark between the lamp and document will repeat and be line down the page.
Mar 28, 2008 | Sharp AL-1642CS Copier
89 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
