Question about RCA P50830BL 50" Rear Projection Television
RCA P50830BL 50 in.
I see in the back of the screen about half way up, when their are pale images the mention " 8 PM " across the screen ?
  • 113 Answers
This is burn in on your set. Something that had those words set on your set for too long. There is no solution to this problem replacing the CRTs would not be cost effective...make sure you do not leave any still images on your tv for extended amounts of time.
Posted on Feb 05, 2008
Rca p50830bl manual
type the rca p50830bl manual on search engine and download the manual
Jul 18, 2013 | Televison & Video
My RCA model P61929 picture is curved inward on the top and bottom
Is there also a misconvergence? If so you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!
hardrocko
Apr 27, 2010 | RCA P50830BL 50" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
Apr 03, 2008 | RCA Scenium PHD50300 50 in. Plasma...
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL will not turn on
You have a shorte chopper diode, on main board look in middle of BD. You will need to change Horizontal output and Block blue caps and big Diode.
Nov 26, 2007 | RCA P50830BL 50" Rear Projection...
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Half Screen
take it apart and check the cables to see if they are seated properly, if you hit it and it comes back, then something is not connected good
May 25, 2007 | RCA PHD50400 50 in. Plasma Television
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
