Hotpoint washer won't drain water out
My hotpoint model number WLW3400SBLWH won't drain out the water when it spins. This happened a few years ago and a repauir man fixed it in 5 minutes. A sock was stuck in the drain tube. Can you tell me how to check for that?
I have a top loading hotpoint and a feather blanket broke open and the washing machine would not drain or spin.
I had to empty it by hand(syphon and scooping), then unplug the washing machine and un hook the drain pipe and water hoses. I then tipped it over and unsrcrewed all the screws to find the pump. There should be a black hose going into it. You must take that black hose off by loosening the clamp. Once I took that off I could see the pump completely clogged with feathers. I removed the feathers and hooked everything back up. It took me about 25 min to do the entire process.
hope this helps.
Posted on Jan 19, 2009
  • Anonymous Sep 03, 2017
    THIS FIXED MY OLD WASHER!!! I did exactly as you said. Mine was full of polyfill, I washed a cat bed and it came apart in the wash. Totally clogged. Took the back off, took the black thick hose off, smelly polyfill was clogging both the hose AND the pump fan-looking thing. You saved me having to buy another washer. Thank you.
  • 106 Answers
Lok from the botom of the machine you will se a filter ,open it ,clean it a put him back in the place
Posted on Feb 05, 2008
I had the exact same problem, My Dogs bed ripped open and the washer would not drain and the pump would just hummmmmm... basically on its way to burning out or starting a fire. I manually removed all the water, tipped it on its side and removed all the screws from bottom and lower back. I could not get the front area to come off so I basically folded the aluminum out of the way, removed the pump... took the 3 screws off and took out all the stuffing... AND DO NOT FORGET TO HOOK UP THE 2 WIRES BACK TO THE PUMP OR YOU WILL HAVE TO START ALL OVER AS I DID!!!!
Posted on Aug 22, 2008
Haier HLP21N washer will not spin or drain water.
ihe clutch is not grabing in1 needs replacing clutch assembly.
Nov 28, 2017 | Haier HLP21N Washer
2003 Saturn Ion won't start in the cold weather
First of all your service light came on so give it a service then have the service light reset then check the thermastac, water levels and the choke is working properly and all the elecric working parts are good
Jul 05, 2017 | 2003 Saturn ION
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma37 washes clothes ok but wont drain or spin
the hotpoint has a saftey factor built into it if the water does not drain it will not spin , the fault is the pump is blocked or broke or the sump hose is block this leads into the pump
to fix take the drain hose the grey one and put it in to a bucket and it will empty the water
if not the sump hose is blocked
if it emptys lie the machine on its side if poss with power off , if it will not lie on its side disconect the water hoses
look under the machine u should see the pump and the sump hose u can remoe this hose put lots of old towels down to catch the water check in side the sump hose for blockages
the pump this on the new models has hex bit screws on it to open check to see if it move freely it should spring back slightly
try this any problems let me know the model number
Jun 28, 2009 | Washing Machines
Hotpoint FFS70S fridge drain pipe blocks with FROST in a few days after clearing. I suspect that the drian pipe is too close to the freezer compartment. Is this a common problem. More to the point, is...
I have the same problem. Engineer said most likely problem with insulation and since pipe is moulded onto the back, it cannot be fixed easily. Defrosting is a temporary solution only. Luckily I kept extended warranty going, they are going to replace it with a new one.
May 17, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
Hotpoint WMA76 Leaking door and soap tray
you may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Jan 23, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
4,235 people viewed this question
Top Washing Machines Experts
