Question about Electrolux ER7926B Bottom Freezer Refrigerator
Freezer not freezing
I have a second hand fridge freezer that worked fine up until i moved house and stored it in a small room. I did leave it for 24 hours before switching on but now the freezer does not freeze. A friend suggested there was not enough cool air circulating so I have moved it to the kitchen where it sticks out like a sore thumb, I wouldnt mind but it still does not work properly. Some things do freeze, like milk and chips, but portions of chilli, bread, sausages are half frozen, in a sort of twillight freeze. Live alone so cant afford new one or man to help so please any advice would be gratefully received! Oh the fridge is very cold!
  • janeyangel Feb 05, 2008
    Ther are 2 temperate settings in the fridge part and both are on coldest settings as I am not sure which is which.
  • elliott 1 Feb 14, 2008
    i have the same problem as janeyangel's,bought second hand transported it laying down in my van,it is in my garage now working the fridge gets really cold but the freezer part does'nt seem like its freezing at all.anything you can recommend for me. thankyou.
  • 236 Answers
Check your temperature setting.
Posted on Feb 05, 2008
  • Felizardo Erilla
    Felizardo Erilla Feb 06, 2008
    If the unit is manual control adjust the temp. setting to standard setting to avoid freezing specially at ref. side.
    If it is digital freezer and ref. setting is also separate you can adjust the temp. of your ref to higher temp to avoid freezing your stocks.
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Why is E522B fridge not cold but freezer working fine?
Hi , First thing you need to check is that the fan is working in the freezer to push the cold air into the fridge. If you have a magnet put it up against the sensor on the door sill so as you can leave the door open.
Jun 03, 2014 | Fisher and Paykel Active Smart E522B...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
Acquired second hand electrolux er3167bn fridge freeze. worked ok for about 10 days then fridge started to get warm, eventually ended up room temp. engineer said to switch off fridge freeze and leave for...
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
May 02, 2009 | Electrolux ER3167BN Bottom Freezer...
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Refrigerator warm, freezer too cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Electrolux ER7926B Bottom Freezer Refrigerator Logo
297 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
