Question about Goodmans DVD2100B DVD Player
Goodmans dvd recorder noise
Thanks for your reply the part in question is all black with a black top and has some sort of hard coating on it .there is a capacitor nearby that has a slightly domed top could this make the other part buz/vibrate do you think
    Sergeant:
  • 201 Answers
Hey cylconesid, I have answered on the other thread, but in short yes. It could also indicate that they are both protecting your circuitboard from burning out due to another problem, possibly a dying motor. The best case senario is that the capacitor was faulty, and the little vibrating thing (thermal fuse)was about to blow as the next level of protection.
Posted on Feb 05, 2008
Dvd recorder not formating after recording.
My Sony DVD recorder RDR-GX 350 not formating the DISK to enable me to record.What`s the problem with it? Thanks.
Dec 28, 2008 | Televison & Video
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
Goodmans dvd recorder not working
Hey there cyclonesid, capacitors look like little batteries, and have a shiny flat top with perforation lines on it. If the capacitor is going or gone, this flat top begins to peak and sometimes show points of corrosion. jpe is associated with thermal fuses which are used to protect devices from excessive ambient temperatures. These are not expensive and relatively easy to replace (if required) by a professional. I hope this helps. Good Luck!
Feb 04, 2008 | Goodmans DVD2100B DVD Player
DVD recorder model DMR-ES30V
I know this is very late to reply, but here it goes anyway. The groaning sound if from the DVD disc slipping on the drive spindle. There is probably a buildup of particles on the rubber surface of the spindle, probably from the DVDs themselves. Remove the metal cover from the unit. Then remove the 4 screws from the top of the black plastic drive and lift off the top. Locate the drive spindle in the middle of the drive and carefully wipe the rubber ring surface on the top surface of the spindle. Use a clean piece of cotton dampened with alcohol. Then install the drive top panel and metal unit cover. You wioll need to repeat this periodically whenever the groaning symptom reappears.
Dec 18, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Oct 09, 2007 | iLO DVDR04
GOODMANS GPDR40
14 August 2007 - Yes it can be connnected like this and will record, even if there is copy protection on the video or dvd - it just ignores the protection. It would be a useless bit of equipment if it couldn't to this basic task. Regards
Feb 22, 2007 | Goodmans GPDR40 Digital Media Player
Goodmans DVD2100B DVD Player Logo
64 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
