Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Projection tv 51"
All red screen,try to set the color
  • cindy40 Feb 05, 2008
    how do i do that?
    OK,GOT IT! THANKS
  • Panasonic Master
  • 8,617 Answers
Try turning the red screen control down just a little bit, see if this helps.
Posted on Feb 04, 2008
  • Sonny Berry
    Sonny Berry Feb 05, 2008
    behind the speaker panel is an access panel you will see a focus block with 6 controls. 3 control switches control the 3 gn focus and the other 3 control the screen/drive controls. just turn the red down a little se if this helps. let me know how you make out and whether you need more assistance.
51 inch projection- can't read words clearly,
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Hitachi 51F500 51" Rear Projection...
My Toshiba 51 inch projection tv has red squares on screen
The model indicated is a projection set and the question is does it look 3d looking etc or something else?
See attached photos of typical convergence problem which MAY be what you have.
SD TECH
May 02, 2010 | Toshiba 51H83 51" Rear Projection...
Color is doubled and picture is bowed
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Toshiba projection tv, blue color out of alignment
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 26, 2010 | Sony KP-51WS510 51" Rear Projection...
Magnavox 51" 51MP392H seems not to have any reds in picture.
his is a very common failure on Projection TV sets.
Screen looks 3D
Also - Dull video problems...
You can see some example photos and find a solution here...
Sep 12, 2009 | Philips 46PP9302 46" Rear Projection...
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Have a green screen on sony kp-51-hw40 projection tv
i got the same problem you have to buy a mirror tube it goes inside the cl,projection you can buy it at radio shak
Feb 01, 2009 | Sony KP-51WS500 51" Rear Projection...
Color problem
Try loading the default settings
Rifaa
Nov 11, 2008 | Sony KP-51WS510 51" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
