Question about Jura Capresso CapressoBAR 351 Coffee Maker, Espresso Machine
Needs new gasket (o ring)
I've searched for this part but can't find it (can't find my parts list for a reference number)
  • Br4dic4l Apr 22, 2009
    The gasket surrounding the water outlet on the espresso side has torn and I need to replace it. Any help locating this part will be most appreciated!
Go to Capresso.com. Go to parts, and use the online part order form and ask for the price on a O-ring. You will need your model type. They will contact you and tell you what you need; or alternatively, just mail your the o-ring.
Posted on Aug 02, 2008
  • 46 Answers
Output shaft gasket for front differential is leaking badly on 1995 jeep Cherokee
the napa part number for the pinion seal for the front differential is 15788
Apr 18, 2014 | Kent Moore J-41676 Front Output Shaft Brg...
GE spacemaker JVM1730 the turntable stopped turning. The next day it started to turn, but stopped. I tried cleaning the parts,but no help
If the oven is STILL heating, but the carousel isn't turning, the symptoms you describe are commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is either WB26X10233 or WB26X10038 (depends upon your COMPLETE model number). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped turning one day last week. Will turn slowly without glass plate on spindle, but not with any weight. Is there a schematic for turntable drive somewhere?
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
repairclinic.com
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is WB26X10038 (listed as item 43). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
May 09, 2011 | Hotpoint RVM1425 Microwave Oven
Sharp Carousel Microwave Convection R-820JS. Oven gets hot but turntable does not rotate causing uneven baking.
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is RMOTDA254WRZZ (listed as item 1-3 under the "Oven and Cabinet" parts section. If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
Apr 28, 2011 | Microwave Ovens
We have a MMV5000 BDW and the turntable has stopped turning
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is W10207571 (listed as item 22 in the parts drawing under the "Internal Controls" parts section.
Apr 05, 2011 | Maytag MMV5156A 1000 Watts Microwave Oven
Need a hose part for my washer
Since you posted no MODEL NUMBER, the only advice I can provide you with are the resources where you may be able to search for parts.
Try any of the websites for illustrated parts diagrams of your washer:
Use your MODEL NUMBER as your search criteria. Another website that you can use is repairclinic.com. They do not have the exploded view parts illustrations like the previous three sites, but they still have photos and often have comparable prices.
NOTE: If your model number does not cross reference to all the sites, use the part number from the Sears site as your search criteria. The Sears site generally has a more extensive list of model numbers. The model numbers may not always cross reference, but the part numbers usually do.
If you need assistance with determining WHICH part you need, please post back with your MODEL NUMBER and let me know. I hope this helps.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Parts lists (i.e. rods, crankshaft, rings) for
Information about your unit can be faxed to you by calling the number below:
From the USA, please contact us at 1-800-323-0620
It may be easier however to look for the model number of the pump only as the 3z497 reference number is of the the complete unit. Look for model number or information on the pump itself and check that number at www.grainger.com. I believe that you have a two stage pump that may still be sold seperately. Good luck on your repair.
Jul 22, 2010 | Dayton Audio Dayton Speedaire Air...
My kitchen aid mixer is leaking oil or grease from the center shaft. When I opened the planetary there was grease in it. is there suppose to be grease there? is there a seal needed for the center shaft?
Hi TIOBEAN, by the symptoms you describe it appears the Center Shaft ‘O’-ring and quite likely the Transmission Gasket need to be replaced. You don’t mention how old your Artisan mixer is, but I assume it is out of warranty.
The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'—whatever that means, and depending on the age of your mixer, where it was stored, degree and intensity of usage; these factors all contribute to the breakdown of the grease into its constituent parts (oil and suspenders), which have seeped beyond the gasket and ‘O’-ring, down the planetary (agitator shaft). Gravity can be very insidious. The residue coming from the agitator shaft is the gear lubricating grease oil that has come out of suspension.
So how bad is this oil leak problem and what can you do to fix it? First, if the amount of oil found leaking was small and if your mixer otherwise works normally with the missing oil you really don’t need to take your mixer apart to ‘fix’ it. The good news, though, is that you can take the mixer apart and 'fix' it, if you feel it is necessary.
It would be helpful to have the Part List manual as a reference. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Having the Parts List on hand will also be helpful as you will have to disassemble and reassemble your mixer to replace the ‘O’-ring and gasket.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, KSM150 and select the file KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61), and save that file to your PC.
Turn to pages 6 & 7, titled:”Case, Gearing And Planetary Unit” and locate Illus. No. 28, Center Shaft & O-Ring; particularly Illus No. 15 & 16, Transmission Gasket and ‘O’-Ring respectively. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Vertical Shaft you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 11, 13, & 14, Bevel Pinion Center Gear, Pin (Vertical Center Shaft) and Groove Pin, respectively.
You should now be able to tap the Vertical Center Shaft (Illus. No. 12) down through the Lower Gearcase housing to access the ‘O’-ring.
Besides ordering a new ‘O’-ring (Illus. No. 16) and Transmission Gasket (Illus No. 15), you’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check them for any other unseemly wear and tear, too.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Did mcculloch manfacture the same piston rings for all their 38cc saws? I have a broken piston ring and cant seem to find one or the part #. Mcculloch MS1838AV 38cc
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Nov 17, 2009 | McCulloch Garden
I need a new gasket for the door.
HELLO IF YOUR BRAND IS A SUB ZERO THEN HERE'S A PARTS LIST FOR ORDER INCLUDING A DOOR GASKET http://www.repairclinic.com/Sub-Zero-Parts?s=t-UCFF+201+-%3d%3db114 IF ITS NOT A SUB ZERO WITCH THATS WHAT IT BROUGHT UP FOR YOUR MODEL NUMBER THEN YOU CAN DO A SEARCH ON THE PARTS PAGE FOR THE WEB SIGHT THAT I JUST PUT A LINK FOR UP ABOUVE
Apr 14, 2009 | Refrigerators
Jura Capresso CapressoBAR 351 Coffee Maker, Espresso Machine Logo
349 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
