Question about Edimax BR-6216Mg Wireless Router (BR6216MG)
Experiencing 15-25KBps slowdown and instability on L2TP
Hey.
when i configure my router to connect via L2TP dialer, the internet connects fine, but i cannot get to my full speed.
i have a 3mbps connection, which should supply me about 375KBps.
instead im getting only 350KBps, and its instable, sometimes it gets even lower.
when i connect my computer directly to my modem i'm able to get to 375KBps easily, and its stable. so the problem must be with the router somehow.
so THEN, i got back to the router and i tried to use PPTP instead, but it got even worse.
so then i tried using "dynamic IP" mode, which allowes me to get an internal IP with my ISP to check my connection between me and my ISP only (no full internet connection, only a lan with some of the ISP's servers),
and when i checked the speed - it was 375KBps (directly to my ISP).
so this must mean there's something bad with the L2TP dialer in the router, right?
im using the right gateway and everything's exactly how my ISP instructed.
any ideas?
thank you!
  • shlomki Feb 05, 2008
    thank you so much for your comment.
    sorry i forgot to mention - im not using wireless connectivity, i'm connected directly to the router with a cat5 rj45 cable. =\
    any other ideas?
  • 22 Answers
The speed sounds normal to me, once you go wireless don't expect 100% of your bandwidth, the other problem can simply be interference from other wireless signals. Best way to defend against that is WPA or other wireless encryption and changing the wireless channel. Let me know how that goes @ copter64 on AIM
Posted on Feb 05, 2008
I've been experiencing internet slowdowns from my regular service.
You've been capped. Contact customer service of your isp
Oct 19, 2012 | aol.ca
How do i turn on the dhcp on my wrt54g2 router
Go to 192.168.1.1
Log into the router (Default username is left blank, password is admin)
On the setup page, make sure "enable DHCP" is checked.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 20, 2011 | Linksys WRT54G2 Wireless Router
I have tried to connect to my work server via vpn but get error message 800 everytime. 'Error connecting to VPN connection Connecting to .................. using ?WAN Miniport (L2TP)?.. Error 800. The...
First thing to try is making sure you have the latest firmware on the router. If you have not logged into it before you need to type http://192.168.2.1 in your browser address bar and log in when prompted. The router by default does not have a password set so it might be worth setting one in system settings. You should find on the menu an option to update the firmware. Read the screen should guide you how do this. If the firmware is up-to-date and you still have a problem try disabling your firewall on the pc to see if it's getting in the way. Don't leave the firewall off if you find it's causing the problem you just have to work out how to configure it to allow the traffic out. The route should allow this traffic out by default.
Dec 02, 2010 | Belkin (F5D8231-4) Wireless Router...
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
Could not access my dlink router di-524 using 192.168.0.1
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
May 14, 2010 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connects but no internet connection being allowed through.
You should configure your Router as a "router" or as a bridge. Usually, you can access the router's IP via web service (using http://ip.address.of-this.router). In this web access, you can modify your router configuration to act as router or bridge, also you have to specify the DNS, DHCP configuration as well.
Maybe with posting your Type of router, i could help you more with it...
Mar 09, 2009 | Zyxel Prestige 334 Router
I keep getting disconnected from my companty's vpn . are there settings i need to configure my verizon fios supplied actiontech router. messaGE is "network connection sssion teminated nc app23711"
- Check the Internet if working properly?
- Access the configuration page of your router and open the firewall settings, uncheck the list below:
Enable PPTP Passthough
Enable L2TP Passthough
Enable IPSec Passthough
- Try to gather some VPN ports to open using the router.
Note: You should have your permission from the connection of VPN to use it.
Mar 04, 2009 | Actiontec (GT704WG) Router
Internet Connects but disconnects suddenly
Who is your ISP?
It seems you are experiencing intermittent connection. Bypass the router and check if the same problem exist when connected directly to the modem. If the internet works fine with the modem.then you have to configure the router correctly.
Aug 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Feb 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Edimax BR-6216Mg Wireless Router (BR6216MG) Logo
127 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
