Tv remote when i push the channel up or down the channels keep rolling
  • Gut Mize Feb 12, 2008
    Channel selector up button is locked and doesn't work, the down button works but only allows certain channels to appear.
    I've tried pushing the button to free it up and I haven't found a way to check channels.
My Comcast pkg should enable me to get chanals 2 thru 243, but my Orion TV only lets me get up to 72. How can I enable the TV to get the rest of the chanals?
Posted on Mar 07, 2009
How do i get aux to work on a rca tv
Some TVs don't have an "input" button(mostly older picture-tube types).In most cases,you select"input" by pushing channel down until you are below channel 3.Start at "3",and keep pushing channel down to 2,1,etc.
Sep 07, 2012 | Televison & Video
Uncontrolled tv
Can you please check the CH+ CH- keys if any of them stuck.
Feb 18, 2008 | Televison & Video
Polaroid tv keeps rolling from ch. to ch.
Check whether the micro-switch [Channel up/dn] have struck or not. This might cause the TV to jump from channel to channel. Refer its user manual and make an auto search for on air programs. If the do not memorize any of the channels, the fault is with its main system memory IC.
Aug 01, 2012 | Polaroid 1720-7 Remote Control
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
Nov 05, 2008 | Philips Televison & Video
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Tv will not turn on manually and when it it does the channels keep rolling
This set has defective tact switches. These are the switches located behind the customer controls at the front of the set. One or more of the six switches will need to be replaced.
Have a nice day!
Toprol
Nov 06, 2007 | RCA F32450 32" TV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
