Question about Compaq iPAQ MP1200 Multimedia Projector
Magenta diagonal grid
Hi, There is a magenta diagonal grid appearing on the upper part of the screen projected. Do you know what it could be? The grid only appears when the projector is showing data from the computer, not when it is on showing a blue screen. I am sending a picture of the grid.
Thank you for your help.
Best regards
Juan Salas
  • js472 Feb 04, 2008
    This is the way it looks
The projector is done.
You will need to buy a new one.
Posted on May 14, 2008
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
Sony 42" - green scribbles on screen
Check the four 1 ohm resistors on the 9-1690 convergence module.
Apr 13, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to align,calibrate
I can tell you how to enter the service menu for Convergence:
Mute,
Mute and hold and while holding then press Menu on front of set
A "S" should appear in upper right corner of screen (means Service mode is engaged).
Press menu again for convergence mode
Press 7 and grid of lines will appear
3 will rotate which color can be adjusted (DO NOT ADJUST GREEN!)
You navigate with 4 to go left, 6 to go right, 2 to go up, and 8 to go down.
5 will stop blinking cursor on screen
With cursor not blinking the same 4,6,2, and 8 will adjust at the point on the screen where the cursor is
5 will make cursor blink again so you can navigate
PRESS 7 to save adjustments and exit.
This set can be a little difficult to get into the "S" menu---you have to do it just right.
Regards, SD TECH
0874d68.jpg This is a typical Toshiba remote---almost any one will work.
IF THE PHOTO AND THE INFORMATION TOLD YOU SOMETHING YOU DID NOT KNOW: Rate this solution as very helpful as I do this here for free.
Aug 13, 2010 | Toshiba 50H82 50" Rear Projection...
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
The top half of the screen is scrambling with wavy lines. Can this problem be fixed?
If you go into the customer menu and select convergence--instructions will appear on screen--select advanced and a grid of lines will appear.
If red or blue are skewed and will not adjust you have a convergence problem-If model ws48511 I have complete do it yourself instructions for this kind of fix.
YOU can post a photo here of what the picture looks like--I will attach one of a typical convergence problem--no two look the same but you will know if this is the problem you have.
SD TECH
Feb 17, 2010 | Mitsubishi WS48511 48" Rear Projection...
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Yellow spot on Sony 55"
Possible dust in light engine? What ever you do, don't blow it out with the set on or hot. This easily equals instant death to bulb.
Apr 23, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Magenta diagonal grid appearing on the upper part of the screen projected
I think you have shifted the lenses from the original position. this problem comes when you reinstall the lens/Color filters after service. if it is the same then check the positioning of lens/filters again.
Viren
Nov 19, 2007 | Compaq iPAQ MP1200 Multimedia Projector
Compaq iPAQ MP1200 Multimedia Projector Logo
123 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
