Question about Amana DLW330RA Top Load Washer
Amana Washer - Pump Assembly
Is there a way to take the pump assembly apart? Looks like a dress sock was pulled into the intake somehow...can't figure out how it go through or around the bucket itself... Any suggestions?
And yes, tried pulling the sock out but only came out so far then stopped..
Thank you!
Gary
  • 57 Answers
There is no way to take it apart if you cant pull it out break it and buy a new pump it got there by over loading the washer
Posted on Feb 16, 2008
Hi there. I have an Amana HD washer NFW7200TW and I am getting an "nd" error code. I have pulled the pump apart to check for blockage and have even replaced the pump, but I am still not able to get the...
I have had this issue (with another model) somehow a sock got lodge in the line by getting in between the tub and the frame of the washing machine. In any event it sounds like the problem lies with the cycle switch
Oct 23, 2013 | Amana Washing Machines
Bush manuals
hi there.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
or read up more at this link might help you some more.
washing machine wont spin or drain Google Search
Dec 12, 2017 | Washing Machines
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Where is fuel pump at for a 1985 cadillac deville
The fuel pump is in the gas tank. Disconnect all hoses and electrical wires from gas tank. lower gas tank. Remove ring that secures the fuel pump assembly and pull assembly out, be careful not to damage fuel float assembly. When replacing fuel pump, replace the sock and the fuel filter.
Sep 10, 2010 | 1985 Cadillac DeVille
HOW HARD IS IT TO REPLACE THE BELT ON A AMANA ALW430RAW WASHER
that belt replacement requires some effort but you can do it with a little patience. then you will have your reward plus your washer will be fixed. you'll need a torx head screw driver ( if u don't have one they sell them at the hardware store) and a 1/2 inch socket. it requires removing motor pump assembly from washer and then removing pump from motor. it will take you a while. it's not as hard as it looks. good luck.
Jan 29, 2010 | Amana ALW480DA Top Load Washer
Amana front load washer door wont unlock
Hi.
Nd is drain error.
Check inside the control assembly, you may have a technical diagram with instructions pocked in there.
You will need to check the drain pump hose for blockage.
If that is not enough to fix the problem, then the fault may be the pressure switch, the pump, or the control assembly.
In that case the best thing to do is calling the support number listed in the owners manual to contact Amana.
Dec 13, 2009 | Amana Washing Machines
F 2 error message
Try the following:
1) Turn off breaker to unit, for safety.
2) removed the front panel, as described above.
3) removed the screw holding the drain pump filter assembly to the main unit.
4) gently pulled the drain pump filter assembly out of the channels holding it to the washer chasis.
5) gently pulled it out far enough to reach over a car washing bucket I had put into the open riser drawer.
6) gently unscrew the filter drain knob enough to release water into the bucket. If your using a smaller drain catch (cooking pan, oil pan, etc) you'll likely need to close the drain knob and empty your water.
7) once all the water was out (~3 gallons I think), I pulled out the filter to find my prize..... Five of my 2 year old's missing socks, including some since he was a newborn. Yeah... yuck!
8) cleaned out the filter and filter assembly... and threw away the socks and other goop.
9) Put it all back together: put the filter back in, returned it to its chasis housing, and put the screw back in the filter assembly. Then, put the front panel back on and flipped the breaker back on.
Good Luck!!
Thanks
Jun 30, 2009 | Kenmore Elite 45986 Front Load Washer
CHANGING A BELT ON AMANA MODEL # ALW990EAW/PALW990EAW
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Amana LWA90A
Belt removal for Amana washer model#LWD70AW
u have to wiggle pump from side to side and up and down shoul losen up and pull strsight out
Apr 11, 2009 | Amana ALW480DA Top Load Washer
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Amana DLW330RA Top Load Washer Logo
226 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
