Question about OKI C5100n Laser Printer
Fuser we keep getting a messge says please repoot printer it sounds like it is going to print then it stops and message code is 010-349 how do we chnge that part
  • super8auburn Feb 04, 2008
    can you refere me any one we are property managers at super 8 motel and need our printer asap for customer reciepts thanks
    Scholar:
  • 130 Answers
1- Verify that the error code that you are getting actually means replace the fuser.
2- To replace the fuser open the lid, the fuser is located toward the rear of the machine.
3- Lightly tap the top you should fell heat. Do not place hand firmly on fuser. It will BURN.
4- look toward the rear of the machine, and pull the two, outside/blue, levers toward you.
5- Lift fuser out by grasping from the side.
6- Before removal leave top open and let machine cool down, unplug machine, and disharge static by using a wrist ESD wrist strap /kit, or touch a ground.
7- Reverse procedure to install new part.
Posted on Feb 05, 2008
  • 106 Answers
This is a too complicated if you a not a serviceman
Posted on Feb 04, 2008
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Error message 093-424
it;s usually an orange feed roller assembly in printer that gets warm and causes toner to cure on paper it is most likely close to being worn as the printer keeps history of how old the fuser is by counting prints or you will start getting paper jams as the feed roller wears down.
Jan 21, 2013 | Laser 3115cn All-In-One Printer
Each time I try to print envelopes on the HP Color Laser Jet CP3505x printer, I am gettig a Fuser 50.2 error message
It's unfortunate Janice but your fuser cannot get hot enough to print on an envelope and the only thing you can do is buy another fuser... sounds like the fuser is still able to heat up enough for regular prints on regular paper so you may want to keep it around for a spare but companies usually sell cheaper when you have a core to return to them... Click Here for Fuser
Oct 03, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
It get half way through the print and stops with error message 13
Bad fuser you have to replace the fuser in this unit in order for it to go again. I do not know right off hand how much a fuser would cost dfor htis unit but ball park around $250 upwards. I hope this information helps Thanks for using fixya.com. I would love to hear your feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | HP LaserJet 4 plus Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
PROBLEM WITH PRINTING
You have problem with your fuser in printer, as the message says. Having the powercord straight to wallsocket, no extensioncables? Try take it out and reinsert if it's removable. otherwise you have to buy a new fuser.
Nov 03, 2008 | HP LaserJet 5200tn Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Fuser 50.1 Error
HI Ann, The problem you are having is the Fuser assy that heats and bonds the toner to the paper needs to be replaced. Once replaced this will fix the problem.Good luck!!!
Nov 28, 2007 | HP LaserJet 2840 All-In-One Printer
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
OKI C5100n Laser Printer Logo
136 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
