Question about Microsoft Xbox 360 Console
Disk not spining at all and no lights
My system turns on but the disk doesnt spin i have it all apart i alson have another one that runs fine so i swiched drives and that one spins but not fast enough the one iam having problems with is Toshiba Part # x800473-019 it was august 2006 model i guess
  • 317 Answers
The power cable is not suppling sufficient voltage/amperage to the drive, try replacing the cable, and trying again.
Posted on Feb 05, 2008
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
The console starts up fine everthing runs fine apart from the disk drive. I have taken apart the disk drive and put it back together, tried cleaning the lens and rails, all that happens is the disk sins up...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
click here to download repair guide
Dec 29, 2010 | Microsoft Xbox 360 Console
The motor wont spin the disk
well sounds like whats wrong with my xbox and the open tray problem..wont read any media. if its still under warranty return it for a fix
Mar 11, 2009 | Sony PlayStation 2 (PS2) Console
1 Answer maytag washer topload was working fine........but when it came to spin mode it just i rearrange everything and took out all my clothes so now it has only water in it but still...
I would bet your door switch is broken or not making contact try to use somthing to push switch down and see if it works when you do that or it may just be broke off
Feb 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Shuttle ab45 v1.2 motherboard, the pc monitor doesn't light up
hi im josh in cebu phils.may i help you. Friend your 478 mainboard doesnt work.? All you have to do is to check the hardware attached on it like hard drive video card memory and most of all the power supply sure you seated it very well to avoid loose connection. this can cause no display or not working. try to check alson if your pwer supply has enough current to support the mainboard and alson the processor compatiblity with the mainboard. good luck hope i helped you.
Feb 20, 2009 | Shuttle AB45 (SHUTAB45) Motherboard
Ps2 disk spinner won't spinn
my disk stopped spinning on my playstation 2 slim so how do i fix it
Apr 08, 2008 | Sony PlayStation 2 Slimline Console
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
