Question about Acer AL1916W 19" LCD Monitor
Screen turns off seconds after image is displayed
My Acer AL1916W LCD monitor turns off just seconds after an image is displayed. This can be repeated by touching the power switch off then on. The picture shows for a few seconds and then goes dark. I opened it up to look for some pots that someone said to try adjust. I looked real hard but there just aren't any.
  • 2 more comments
  • tech133 Feb 04, 2008
    I am using VGA. The PC does not have DVI out. Yes, the PC works fine on another screen.
  • tech133 Feb 05, 2008
    I tried 800x600 and 1024x768 (60Hz) but the screen always says 'No Signal' via DVI. Only VGA input gives a (temporary) picture.
    I tried 3 PCs already - same symptoms - it's the Monitor that has the problem...
    Which one is bad: the LCD screen OR it's power supply?
    Master:
    Sergeant:
  • 440 Answers
Are using dvi cable is yoour out put on the cpu ok video out video card ect u test antehr screen on it test this one on differnt one if it bad its bad u cant usally get parts for these priotory
Posted on Feb 04, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 04, 2008
    your screen has dvi right in try that port with cable then adpoter vga to dvi
  • nick helpap
    nick helpap Feb 05, 2008
    so vga works what about try using this off your other pc or labtop se if it works if not bad power in side it nogood they sumtimes die when on bad power strips or in storm porer go out
  • nick helpap
    yup bad lcd power going to it ect sell for parts on ebay best bet man we tryed it al
My acer AL1916W displaying vertical lines and images or flickering any help
ITS POWER SECTION'S CAPACITOR HAD BECOME WEAK MANAGE TO REPLACE IT.
Feb 04, 2011 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Monitor keeps blacking out, I need to do a power drain but can't remember how to do it!
i have the same problem i think. like, if i dont use it for a long time, it'll display a nice perfect image, but then it goes black. everytime i turn it on after that its only about 3 seconds then it goes black. i have 2 monitors right now and i know its not my pc.
Oct 09, 2009 | Acer AL1916W 19" LCD Monitor
ACER Al1916W goes blank in 3 seconds. It shows ACER splash screen for a sec., the desk top for .5 sec, then goes black. There is a very high pitch squeel each time there is any display. Power switch turns...
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Grey Shadows for everythng on monitor
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Sep 02, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor '' no power''
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Feb 28, 2008 | Acer AL1916W 19" LCD Monitor
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
306 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
