Question about Sharp 27C-240 27" TV
Sharp TV Problem
I just bought a 27 inch Sharp TV about 3 year old. It makes a continuous quiet hissing sound from the internal components when the set is turned off. Is this normal? Our other TVs do not do this. Everything else seems fine. Picture and sound are both great. Thanks.
  • 106 Answers
Everythin ok that what you hear is work of oscilator from tv set
Posted on Feb 04, 2008
6ya staff
SOURCE:
Tv smoking
if you say you heard a hissing sound that can be fly back cap or the eht leaking electrolytic capacitors can over heat due to lack of discharge as the are about to open or "bust" best way check for dry joints or any physical damage.
Aug 13, 2013 | Dynex Computers & Internet
LCD Television Philips 42PFL9900D/10 Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Hissing noise from Philips 42PFL3603D/27
Turn on the Viewsat 2000 first and after 20 seconds, power on the Phillips42.
Aug 01, 2017 | Philips Televison & Video
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Televison & Video
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Flickering image
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Feb 23, 2008 | Emerson EWF2703 27" TV
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Sharp 27" tv
You got the right idea,use the ext.imput on you tv and use the vcr to change the channels,you can check the solder conections in the tuner ,ussually the ground gets loose after a while but if you are not too familiar with tv service and dont want put any money in this set use your vcr.If the quality of the picture is still good then is worth keeping it.Let Us know if you need more information.
Oct 30, 2006 | Sharp 27C-240 27" TV
Sharp 27C-240 27" TV Logo
181 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
