Question about AcerPower 1000 (AP1000EA380M) PC Desktop
AcerPower 1000-EA380M No Video
I have an ACERPower 1000 that powers up
There is drive activity as well as lights, but no video..and also no post beep.
I have changed to numerous monitors (which all work fine on with systems) but no video to display...
OS - Windows XP (Media Center)
Processor - AMD Athlon 64 3800+
RAM - 512mb
HD - 250gb SATA
No externally attached devices except (USB) KBD and Mouse
  • 1 more comment
  • g0alieman33 Feb 05, 2008
    I cleared the CMOS and still have the same issue
    there is no normal post (with or without the monitor) I have lights on the computer, driver activity but no post beep nor do I get any blink on the keyboard lights.......
  • sergei_od Dec 19, 2008
    Hi!
    I have the same problem. Did you solve yours?
    Probaly something was burned on motherboard.
    Let me know what did you do finallly.
    My e-mail sergei_od@yahoo.com
    Guys discussed similar problem, follow link
    http://www.fixya.com/support/t953090-ace...
    Hope to hear from you. Serge.
  • 106 Answers
Open the cover,try to find jumper "c-mos clear",probably is green,or red. put it on,then power on the machine abaut 3 -5 sec.then shut it down. then put the jumper in prevoius position and start macine normaly.on screen you have a note "c-mos clear,enter setup......",enter set up and chose auto configuration,save and exit and everything is ok.
Posted on Feb 04, 2008
Find the gpu on the board it should have a small heatsink on it press on that and see if it fires up
Posted on Mar 08, 2009
Acerpower f2 bios beep codes
The beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM modules and Cmos battery sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
hope this helps
Jun 22, 2012 | AcerPower F2 PC Desktop
Acerpower sv wont turn on, the fan only keep spinning with no display. And no signal beeps
Good day.
Primary culprit is your motherboard and the processor. But just to be sure, check your power supply cables going to your board and the voltage. Next, to isolate the problem and the board/cpu, remove all the device (cards, memory, drives, etc.) then power on, if there still no beeps then your board is dead, no way to check for the processor unless you have a good processor.
Good luck
Ted
Sep 13, 2010 | AcerPower SV PC Desktop
AcerPower 1000 (AP1000EA380M) PC Desktop: i cannot install win xp on acer power 1000...
Hi! Try to go to bios menu via F2 or del while system is starting up.Go to sata operation, change IDE to AHCI or vice versa, save settings then try to reinstall os(win xp) again via booting to the disc (F12) and choose cd/dvd or odd...hope this helps...Cheers!!!
May 18, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
AcerPower F1 desktop boots fine after about 10
More likely it's from overheating; if it would be from the power supply ithe shutdown would be more random.
But it could also be a malware infection - especially if it happens EXACTLY after the same amount of time . Check what processes are active just before shutdown .
Nov 09, 2009 | AcerPower F1 PC Desktop
No power on Acer 1000ea380m
check the power adapter or charger first then the dc power connector... if its okay check the board ...
Sep 08, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
Won't boot and doesn't even get to BIOS
You definitely have a hardware issue so you need to go through a process of elimination to figure out what it is.
1) try another video card (if you are using a video card)
2) try your on-board video (if you have it)
3) take a look at your motherboard to see if any capacitors look bulged
4) try another power supply (although the computer is getting power, it might not be getting "good" power)
Usually if it is the memory you will at least get a beep. This sounds like it is probably your mobo if it isn't your video card.
May 26, 2009 | Racer AcerPower F5 PC Desktop
Can't install XP service pack2 on my AcerPower f6 computer.
Did this machine have Vista intalled originally? I checked Acers' support page for your model and I didn't see a xp sata driver.
Apr 14, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
AcerPower 1000 keeps shutting down
you mean the computer power off automaticaly.
check the all cable of mother board.
Jan 21, 2009 | AcerPower Sn PC Desktop
Acerpower 1000 - won't boot (or POST);
I had to start my acerpower 1000 four or five times. When it boots into windows, it lasts for about a minute, then shuts off.
When booting into safe mode, the PC will stay on forever. I would think a hardware problem would cause it to always shut off.
This is not a solution, but something I have observed about these machines.
Aug 21, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Computer boots up but no video display.
If it has onboard video and you've added a video card, sometimes you need to disable the onboard video in the BIOS as it won't send output to both when they are there. I would try a different monitor and eliminate that as a possibility also.
Mar 24, 2007 | AcerPower F2 PC Desktop
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
