Question about Acer TravelMate 4150LCi Notebook
Wireless configuration During the last 2 months I have been experiencing problems with my wireless connection. I use BT broadband and have asked them repeatedly to restore the wireless connection. This they have done but it doesn't last. The engineer said 'the wireless zero configuration automatically stops itself when managed by windows'. Please can you tell me how to resolve this problem. Sue
  • Chris Lemke May 11, 2010
    Please.. email me directly at chrislemke@lbsenterprises.com
    or message me at christalnet@hotmail.com
    @yahoo.com
    ICQ 147169792
    and will try to help you more
    It would be helpful to now what version of windows your are using. I had a similar problem which I resolved by replacing my wireless modem with another kind. At any rate if you could give more information on what BT has had you try and your machine specs I am sure someone can help you.
Christalnet,
I'm afraid I'm a technical novice. I'm using windows xp, and each time bt have offered assistance they have taken over the computer and wizzed around checking programmes, changing settings, changing channels and attempting to connect to the hub. I've been in the dark as to what exactly they have adjusted, and each time I've been connected to a different technition.
Nowire
Posted on Feb 05, 2008
Hi, since having a new BT home hub, my inspiron 6400 will not connect wirelessly unless I do a 'repair' with it. Sometimes it detects broadband but wont connect wirelessly. My son changed the channel...
Most people have to just work out the configuration by them selves BT do offer a lot of support (0800 022 33 22) Their equipement is pretty good and widely used.
By the way the most least used channels are 1,6,and 11 there might be a default but these are the most complete channels which do not overlap(RE;
cnannel 1]--2.412 Centre frequency(ghz)
channel 6]--2,437
channel 11]-2.462
Mar 14, 2011 | Dell Inspiron 6400 Notebook
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
We changed over to bt last week and since then we are having the same problem that we had with the post office who where our supplier previously, some times we are able to connect on to the net other times...
This method will hard reset the wireless and LAN drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, then right click on the LAN (it should be under the name Realtek) and unistall that, reboot the PC and wait for windows to detect the wireless card & LAN card and install the drivers for it, these will appear in the system tray (bottom right hand side) when its done try to connect again.
Also check your internet speed, you can do this at speedtest.net.
If the download speed is less than 1Mbps (megabit per second) they you are going to have real difficulties getting and staying on the internet. If that is the case you will have to take this up with BT as the lines maybe old and BT need to replace them.
This could have been the initial problem that the Post Office had.
Good luck and please let me know how you get on.
Sep 14, 2009 | Dell Dimension E520 PC Desktop
I tried to secure my Linksys Wireless-G Broadband Router last night and set it up to require a password by going to 192.168.1.1. I also did something(I can't remember what) on the linksys website that made...
When configure security, is better to connect to network cable. Because once u setup the wireless key such as WEP or WPA, u will be log out from the wireless connection and u need the correct key to login.
Feb 26, 2009 | Linksys Wireless-G Broadband Router
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
BT ADSL prob: ATM OAM F5 segment ping - OAM F4 FAIL
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
hope this helps
Nov 20, 2008 | Computers & Internet
New Laptop Connection
Are you connecting and configuring using wireless or cable?
Sep 07, 2008 | Linksys Wireless-G Broadband Router
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Acer TravelMate 4150LCi Notebook Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
