that post is hard to read and no PC model told at all. Cq61?
the PC must run on AC power pack with no battery there.
does it?
99% of all cases like this the battery is bad.
you do know that most charges LIE to you when the battery is bad.
this is a fact, so savvy owner have a good spare battery.
not you so are stuck in a conundrum.
I will not go in to my 10 page thesis on why that happens
but lets so an analogy,
I look at my car and the tires look ok, but up close not.
the charge can not look inside any battery to see 1 cell is bad physically i some odd way.
there are only 3 causes.
1: wrong power pack AC mixed up with other PC etc and is wrong.
2: bad battery is 99% of all causes, for sure, even 1 year old abused
and that means running on battery all the time kills them dead fast.
ok
https://batteryuniversity.com/ teaches why>?
3: bad charge chip and needs new mobo or $300 gee that cheap battery new looks like a great guess no? $15>? as does #1
"but the charger alone"?????
this i think means battery is gone???????? faIls?????
if true that means the AC power pack is bad or wrong.
the charger is a chip and is on the mopo not the power pack
the power pack is just that at AC to DC power supply pack
a key fact to learn, where things really are to diagnose real problems
learn to call it a power pack and seems yours is DOA./
all VRM and charge chips are on the mobo !
even shorted battery can cause the PC to go dead
as it overloads all power rails in he PC. (and common)
some PC ive seen , used, (wrong mix)
are sold with the wrong power pack ! the cheap one is low watts;
so seller do that BAD ACT.
PC that need 30w, 60watt or 90watt pack ,.must use the right pack.
that is because most PC have 5 CPU or 2 or 3 GPU choices new or 4 banks of faster RAM. called OPTION. new.
and burn lots of power, so the 95watt pack must be used.
or H3LL to pay for sure. and PCs run on the highest power watts pack in the series. of PC not told by you at all
no service tag data told so not waxing smarter possible.
