Question about Canon CanoScan N670U Flatbed Scanner
CanoScan N670U not communicating with computer
My Scanner is not communicating with the computer. I tried plugging it right into my mac mini, and I get the same message. i tried plugging it into a hub (with a power cord) still no go???
  • Anonymous Mar 12, 2008
    My scanner worked fine till now. I connected the scanner and the computer (Mac OS 9) and opened Canoscan Toolbox 4.1, then CanoScan Toolbox X, pressed Scan-1 to scan a photo ( there was no sign of life in the scanner), and a window popped up, saying "Cannot Communicant with scanner. Cable may be disconnected. Check status, Scanner driver will be closed." the cable seems fine to me. and I was doing what I did before, but I don't know what it means about "status" and "the driver will be closed," would you please help me? Thank you!
  • asteiner Oct 01, 2008
    No sign of life from my scanner when I try to use it with the same computer as before - a Mac.
Iwant drivers for canon scan n670u
Posted on Mar 26, 2008
I have downloaded the scanner software for the canon CanoScan N670U more than once, but it is not opening or running on my mac.
This was a problem with Mac's and this scanner (are you using 10.3 OS)?
Try unplugging the scanner then replugging it in, sometimes after the mac sleeps and is woken, the scanner will not be recognised (happened on XP and Vista PC machines as well)
also try using image capture on the mac rather than the canoscan toolbox software.
If you want to give installing the drivers and software another go, download the software and driver remover tool from canon's site before re-installing
Jul 27, 2011 | Canon CanoScan N670U Flatbed Scanner
I am trying to install canon flat bed scaner on my laptop windows 7 and I am unbale to locate the drivers for windows 7 (twain) , I intall aarcsoft photo base and it can't locate twain or drivers for the...
Sorry, but the compatibility sites say this is not compatible with Vista or Win 7.
They word is that Canon has no intentions of writing a win 7 driver for this unit.
You should probably backstep to Win XP so you can use this scanner.
These manufacturers are letting Microsoft make the hardware obsolete due to lack of drivers... a conspiracy???,
Jan 13, 2010 | Canon CanoScan N670U Flatbed Scanner
Cannot install the scanner
Here is the canon driver download site http://software.canon-europe.com/products/0000475.asp
Jun 11, 2009 | Canon CanoScan N670U Flatbed Scanner
Need a driver for a CanoScan N670U Scanner for Mac 10.5 OSX
Basically you should not scan through Photoshop but should use your scanning software as a stand-alone application
Apr 23, 2017 | Canon CanoScan N670U Flatbed Scanner
Canoscan N676U
If you are using Mac OS X 10.5.x, then you're out of luck. That scanner is not compatible. If it is an earlier version of Mac OS, then check out the website.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=6626
Jul 05, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Are you referring to the scanner or the computer not having a light on?
The scanner only lights up when it is scanning. If your computer is running ok, check the Apple System Profiler to see if the scanner is detected. What Mac OS are you using? Leopard is not supported with this scanner model.
May 30, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Apple laptop M8407 vs. n670u canoscan
Keep in mind that connecting a specific scanner to the computer would have nothing to do with the computer now powering on unless there are physical computer hardware problems. Disconnect any uneccessary external peripherals from the computer (printers, scanners, webcams, etc.) and see if the computer will power on. Remove the computer battery and put it back in. Check power connections and test to make sure the electrical outlet is working by plugging something else into it.
Canon CanoScan N670U Flatbed Scanner Logo
296 people viewed this question
old marine
old marine
