Question about Harman Kardon AVR 100
How do I connect a turntable
There is not a specific jack for "phone in". what are my options for connecting my turntable. I do have a DAK mixer that would alllow me to connect to a "line in". again, what are my options.
thank you,
jm
  • 185 Answers
I agree with 'radio head.'
Turntables require a particular frequency response and the input needs to be correctly equalised to accommodate this. If your amp had phono inputs these would be equalised internally.
Unfortunately, many modern amps no longer have phono inputs. There are two possibly three options.
1) You could obtain a turntable that includes built in Phono eq
2) As 'radio head' says, you can obtain in line active equalisers. These are called RIAA Equalisers (Equalizers if you're in the US) or RIAA preamps. This allows you to plug your turntable into a small box, then plug the box into one of the audio inputs on the back of your amp.
3) You may be able to adjust your mixer to the required frequency response and use it as a preamp.
What you cannot do, regrettably, is just plug your turntable into an ordinary audio input. It will not do any harm if you want to try it and it will make a noise, but you won't like it!
Posted on Feb 04, 2008
You will need a phono pre amp there are small one made and this will allow you use any line in you like...parts express has them and radio shack use to carry them.. maybe try guitar center or a dj supply.
    Problem Solver:
  • 5 Answers
You may be able to plug the phono into any other jack not in use ,such as tape ,aux...etc give it a try
  • groovy128
    groovy128 Feb 06, 2008
    wondering if this solution would require grounding the turn table
How can i connect speekers with just copper wire to my mixer with red and white jacks
You didn't list the model number of the mixer, but from your description, your mixer does not have power amplifier outputs for speakers. The red and white RCA jacks are out puts that would plug into a power amp input, and the speakers would connect to the power amp, as in a PA system.
May 21, 2014 | Audio Players & Recorders
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    I received the turntables and mixer but Im having trouble installing everything together. Is there any companies that can help you install the turntables, mixer, and speakers
    Not to worry if you can take some pains and be confident. First of all arrange the turntable, the mixer, the amplifiers and the speakers. Connect the turntables two RCA pins to the PHONE pins L and R. of the mixer. Using another set of RCA cables to connect the output of the mixer to the amplifier's AUX inout L and R. Try to connect the red and white in accordance to the L&R. The speakers should be cconnected to the left and right of the amplifier's main. if you have front and rear use them but connect with the polarity of the red and black polarity . Use a good power supply multipin unit to connect all the power. Do not switch on until you have checked once again. Now switch on and play your favourite record. DO take time to do and you will suceed. Good day
    Jul 11, 2010 | Stanton ST-150 Turntable
    How do I use my laptop like turntables, PLEASE HELP
    A trip to your local Radio Shack should solve your problem with the purchase of a mini phone jack to double RCA type (red and white) leads cable.
    Jack into the audio out of your Macbook and into the input of your choice on the mixer with the RCA jacks and you are good to go.
    May 10, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
    Cant connect my Numark PT-01 to my Numark DM950 mixer
    What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
    If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
    - OPTiC
    DIY Yourself DJ Repair Videos
    DJ Equipment Sales
    Jan 08, 2009 | Audio Players & Recorders
    Connect turntables(technics SL1210MK5) to a mixer?
    None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
    - OPTiC
    DJ Equipment Repair & Service
    A DJ Pro Audio Co.
    Dec 17, 2008 | Technics SL-1200MK2 Turntable
    Connecting a behringer djx700 mixer to a panasonic amp
    The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
    Check that first and get back to us if you still have problems/questions.
    Dan
    Aug 21, 2008 | Audio Players & Recorders
    No music
    Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
    No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
    If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
    1) Tonearm
    2) RCA Cables
    3) Cartridge
    There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
    But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
    - Davis
    DJ Pro Audio
    www.DJPROAUDIO.com
    www.DJPROLAB.com
    Jul 16, 2008 | Audio Players & Recorders
    Turntable connection
    you can not connect a turn table in any other input source other than Phono input my friend. turntable has got very weak signal thathas to be pre-amplified before getting a signal just right for a CD/Tape DVD input. you require a phono am to get an audio signal.
    Mar 29, 2008 | Audio Players & Recorders
    Harman Kardon AVR 100 Logo
    607 people viewed this question
    Top Harman Kardon Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
