Question about Goodmans DVD2100B DVD Player
Goodmans dvd recorder not working
My goodmans GDVD301R dvd recorder has stopped working . it has a loud noise like a fan running which when i looked inside is coming from what i think is a capacitor this capacitor is also vibrating a lot .Is this at fault and in need of replacement or is something else at fault causing this. the part in question is all black and has nothing on it apart from letters jbe.hope you can offer some advice
thanks tanya
  • tanya young Feb 04, 2008
    thanks devocap the part making the noise and vibrating is all black with a black top ? but there is a capacitor neerby that has a domed silver top as you described . could this be what is making th other part buz/vibrate
    Sergeant:
  • 201 Answers
Hey there cyclonesid, capacitors look like little batteries, and have a shiny flat top with perforation lines on it. If the capacitor is going or gone, this flat top begins to peak and sometimes show points of corrosion. jpe is associated with thermal fuses which are used to protect devices from excessive ambient temperatures. These are not expensive and relatively easy to replace (if required) by a professional. I hope this helps. Good Luck!
Posted on Feb 04, 2008
  • Devocap
    Devocap Feb 04, 2008
    Hey there cyclonesid, that is where I would guess you problem is located. The deal is however that these things are there to protect your machine. If they go , it is either a sign of a bad fuse or capacitor, but also likely a sign of a deeper problem which may be dying motor. I suggest you get the capacitor replaced and the thermal fuse (black vibrating thing) checked, and ask technician to check other elements in immediate area. Good Luck!
I have a goodman cple42-1 The fan motor outside was not running and I was able to get it started but the house wont cool now. air is blowing but not cold.
the capacitor is possibly bad the indoor fan uses its own capacitor while the outdoor fan and compressor share a capacitor
Jun 29, 2012 | Goodman CPLE24-1 Air Conditioner
What 39 s your problem Goodman gas heater the fan is loud and makes a clunking noise
Check the fan wheel to see if something got "sucked" in.Ex.paper or insulation. If wheel is clear but looks bent do NOT bend it back, it should be replaced to spin TRUE
Oct 28, 2011 | Goodman GMS90703BXA Heater
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
I cannot get a fachi universal remote to work anything
THE THREE DIDIT CODE FOR A GOODMANS XPRO DVD RECORDER GDVD301R .FOR MY FACHI UNIVERSAL REMOTE
Jan 17, 2011 | Televison & Video
I have a goodman air conditioner and the fan stopped I felt heat from the top and it was loud what could be wrong. the builder installed it about 2.5 yaears ago.
You are probably hearing the compressor run, thats what is loud.
The compressor should cycle on and off to protect itself. You are
probably looking at replacing the fan motor.
Aug 11, 2010 | Goodman CLJ36AR42 Air Conditioner
3 year-old Goodman compressor/heat pump terribly loud @ start
Without being there to see it and have only your description in front of me, it sounds like the fan blade could be out of balance.......but it sounds more like a loose fan blade hub. Most Goodman units offer a minimum 5 year parts warranty. The Labor warranty is questionable, but the installing contractor or the Goodman Distributor should be able to give you that information. Of course this would cover manufacturer problems and not physical damage. As far as a history of this problem with Goodman..........I've seen it with every brand. If there is a problem getting it under warranty, you might be able to purchase the blade yourself. Before replacing the fan blade, I recommend disconnecting the motor wires from the contactor, tape off the ends and remember exactly where they were attached.....then start the unit to see if the noise is still evident, if so, it's probably your compressor. I recommend a certified repairman....not the one that quoted you $800.00. If you hear only the compressor start up and not the loud noise you are discribing, then try replacing the blade first.
I hope you find this information to be very helpful to you. :-)
Mar 16, 2010 | Goodman CKL60AR60 Air Conditioner
Dvd player/recorder wont turn on although power going through machine model gdvd301r thanks alot
Defect power ic board. Take the thing back to the shop for exchange or refund. No receipt or out of warranty? Chalk it up as a loss and purchase a new one.
Cheers
Feb 11, 2010 | Televison & Video
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
LG DVD recorder (super)
Mine did to, it was the fan at the back of the recorder. I fixed it by inserting a cardboard spacer between the fan & the case.
Regards
Gordy
Apr 18, 2008 | LG RH177 DVD Recorder/HDD Recorder
Goodmans DVD2100B DVD Player Logo
201 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
