Question about Kenwood KDC-MP7028 CD Player
Rca ok like the labels on the rca wires on the back of my radio have worn off and im trying to hook my amp back up and i cant remember which one is the subwoofer wires there is like four of the and two of them still have the labels on them the Aux in wire and the front wire r still labeled there is a short one and a long one thats labeled im already having enough problems with cuz for some reason. also there is a buzzing from one of my speakers in my car just when i turn on my lights
    Master:
    Sergeant:
  • 440 Answers
Long one black ya is sub ok or direct on unit
Posted on Feb 04, 2008
I have a clarion m 309 radio and I'm trying to hook up a fusion FM 402 amp for a sub woofer. I had all speakers playing but, I could not control the volume of the sub with the radio. I need to know...
Amps usually receive their signal through RCA wires. Your radio should have one pair of RCA outputs on the back. (red and white) You will adjust your subwoofer volume by adjusting the gains on the amplifer (little knob next to the RCA inputs of the amp), then you can turn up the bass on your radio.
Sep 06, 2011 | Clarion Car Audio & Video
I have a keenwood indash dvd player i want to hook my amp to it but it dont have rca jacks so how do i do it
If your indash radio does not have RCA outputs, you can do two things. You can purchase a line level converter and hook it to one of the rear speakers. This will allow you to tap into the speaker wire, then convert the signal to RCA. Then you plug your RCA cables in there. The other (my recommendation) is to purchase an "add an amp" wiring harness. This harness will install between your radio and vehicle harnesses. It will have RCA output and remote wire. Then you run those back to your amp and there you go. You can find these at the scosche or PAC websites. You can also try www.crutchfield.com
Aug 29, 2011 | Kenwood Car Audio & Video
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
I cant figure out my amp wire color code
every amp is wired the same its pretty easy... the red wire is your positive and needs to be hooked up to the battery.. black is the ground and needs to be touching something metal in your car. blue wire is remote start wire it goes from your radio to amp then plug your red and white rca cables from amp to radio
Dec 15, 2009 | Pioneer Car Audio & Video
My amp wont turn on
normally it's the blue wire marked power antenna on the back of the radio it normal size would be about a 12-14 gauge wire size
Jul 26, 2009 | Kenwood KDC-135 CD Player
I NEED DIRECTIONS ON HOW TO CONNECT MY AMP TO MY CAR
We'll start with powering the system up. YOu will need to run your power wire from the battery. It must have a fuse just after the battery. Run the negative to the chassis of the vehicle. On the back of the radio, there will be a blue wire labeled remote/antenna. This wire needs to be connected to the amp. This is what turns it on and off when you power up the radio. Next you will need to run the RCA cables from the back of the radio to the amp. Now you are ready to hook up the sub woofers to the output side of the amp.
Mar 27, 2009 | Soundstorm 500.2SL Car Audio Amplifier
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
A electronic subwoofer crossover
connect speaker wiring for car to speaker wire side. plug the rca's into the amp ground the ground wire. run a live from the battery to the power on the crossover and run the remote wire to the blue (iso connector) wire coming from the back of the radio
Jul 24, 2008 | Car Audio & Video
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
Kenwood KDC-MP7028 CD Player Logo
61 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
