Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Shifted Picture We have hod our TV for about 5 yeas and have noticed that the whole picture has shifted left about 1 1/2 to 2 inches. This cuts things off on the left side of the picture. Any ideas on how to re-aim or adjust the picture back to center.
  • hownelp Feb 04, 2008
    If your talking about the ring in the remote, that didn't do anything. Thanks anyway
  • 4 Answers
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Posted on Oct 03, 2008
    Problem Solver:
  • 7 Answers
I have the same set and that happened to me after i put a dvi to hdmi adapter on my tv and started running my set on av 5 however if i go back to av 4 it no longer does that but the picture isnt as good so i live with it (the better pic)
Posted on Apr 21, 2008
  • 8,596 Answers
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Posted on Feb 04, 2008
Picture shifted to left 1/3 and left portion shows on right side 32" sony trinitron (not flat screen)
Probably caused by a failure of certain bipolar electrolytic capacitor(s) in the area of the high voltage circuit.
May 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Jan 04, 2010 | Televison & Video
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Apr 29, 2008 | Sony KV-32FS13 TV
Toshiba TV picture has shifted high
if it cannot be adjusted then there is a problem in tv. your problem is in vertical output circuit Can this be corrected easily ? yes or do I need to start looking for a new TV? I love this one and would like to keep it a while longer. not to look for new tv.you will keep it for longer that has a picture that recently shifted upward and now cuts off about 1 inch of the top of the picture. Otherwise it functions properly. your problem is in vertical output circuit please check 1loose contact in vertical output section 2 capacitor defective in v/output. it is a common problem. it is a not a major problem. if you are not tech person get it done by skilled tech. hope this will help.
Sep 30, 2007 | Toshiba 32A33 32" TV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
Aug 15, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
