Tape stuck in VCR, won't eject.
I recorded a program on a tape. The following morning I tried to play it back. I hit Rewind and didn't wait for it to stop and pressed Play. The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit. Any suggestions? sony slv 760HF All of a sudden, the VCR will not insert a tape. It keeps rejecting it.
  • 883 Answers
You posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Posted on Feb 05, 2008
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Mar 08, 2010 | Sony Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Jan 24, 2007 | Emerson EWV601 S-VHS VCR
Televison & Video Logo
1,317 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
