Question about JVC XL-MC334 200-Disc CD Changer
Disks do not feed properly
Hi there....
After the disks stopped playing and I heard wearied mechanical sounds when fed-in, I opened the box and saw that the disks do not feed in properly. Then the changer gets it out and keeps on trying the next disk, and the next (after a few disks it succeeds).
There is a shelve which closes on the disk when it is at the spot. Right?
If I tap on it slightly then the disks fits well into its place and starts to play.
Appreciate you suggestion
Jimmy V-Plex
  • dtlover99 Jan 17, 2009
    the cd arm does not pull the cd all the way and the cd does not sit properly for it to start playing therefore it will reject that cd and go to another one until it sits properly
Mine just stop playing. It's like the motor went out?
Posted on Oct 01, 2008
  • 983 Answers
Open the player wit door ejected then clean the dust particles inside it wit dry cloth especially near the rubber belt which is connected to the dc motor... clean the lens also then check whether any screws are loose if so tight it then try playing....
Posted on Feb 06, 2008
6ya staff
SOURCE:
My lg blu ray dvd players doesn't read my disks
Sounds like you have a faulty player, best to return it under warranty
Oct 20, 2017 | LG Televison & Video
Why does my DVD player say STOP in Upper Right Corner?
Sounds like your laser mechanism is no longer capable of reading a disk. If it does it with other disks then you can be sure of the diagnosis.
And due to parts cost and labor a repair is usually not cost effective.
Apr 28, 2012 | Magnavox DP170MW8B DVD Player
Toshiba SD-K625 5 disk player won't play DVD but will play CD
Could be that the laser mechanism has lost its ability to focus properly on the dvd disks. U might want to try a firmware upgrade just in case the player has corrupted software. If not effective, then it is time to go shopping since a repair is not cost effective.
Mar 31, 2017 | Toshiba SD-K625 Multi-disc DVD Player
When I go to play a dvd, a clicking noise is heard and the movie will stop playing. With some dvds I cannot play them all as the noise begins immediately. What can I do???
Sounds like the laser head that reads the disk is getting lost and trying to search for the track. This is often caused by a dirty laser head or dirty disks, try using a cleaner disk (available at Wal-Mart or just about anywhere) Follow the package instructions and clean the laser head see if that cures it.
Sep 15, 2009 | Emerson EWD2203 DVD Player/VCR
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Buzzing sound and can't open stereo
Again RCA stereos **** for this factor, cheap transformers, replace the transformer and see if that helps as it seems to be the most problem with most RCA systems I've repaired in the past.
May 09, 2008 | RCA RS2656 Shelf System
Turntable does not turn
First, try cleaning the lens.Use a good quality Lens cleaner. If this does not work, Open machine and see for mechanical problems - broken belts, etc.
Sep 30, 2006 | Teac PD-D2410 5-Disc CD Changer
JVC XL-MC334 200-Disc CD Changer Logo
283 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
