Question about HP PSC 2175 All-In-One InkJet Printer
Carriage Jam I just posted another question about this same thing, but I just noticed something different. When the ink carriage is to the left and tries to go to the right, it is stopped by a curved black plastic piece that has something to do with the paper. There are 2 of them that lift up when it's trying to print. The left one is actually slightly bent because the carriage keeps trying to get passed it. Any idea's on how to get it to go passed it? I think that's what it means by "jam".
  • Gabelmom66 Feb 08, 2008
    It won't reset. I do what you said and it seems to ignore that i'm even pushing buttons......the jam message just comes up.
    Novelist:
  • 57 Answers
I understand that you are receiving Carriage jam error.
Please follow the below given instructions to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=90809&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Posted on Feb 08, 2008
Globs of ink in carriage bay j5780
Alcohol will help in cleaning the build up.Make sure you turn off the machine before cleaning. After the bay is dry, insert the cartridge and on the display, using tools button, clean the cartridge. After that using tools button do the allignment process. good luck
Nov 27, 2013 | HP Officejet J5780 All-In-One InkJet...
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Clear carriage jam -hp d7460
Carriage jam usually comes from ink on the clear encoder strip that runs across behind the carriage. You need a damp Q-tip to clean from one end to the other, The other thing, on the HP is the cleaning station on the right gets gummed up with old ink and won't go toward the back fully, stopping the carriage.
Sep 17, 2009 | HP Photosmart D7460 Printer
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Carriage jam
I had this same problem with an HP2355v. There is a carriage directly below the print heads (on the right side of the printer) where the ink is dumped during the cleaning process. The carriage needs to be able to freely move (fore and aft). I noticed that my carriage was really gummed up on the left side of the carriage. I cleaned the edge of the carriage and the channel where it travels with alcohol and qtips. The carriage now moves with minimal effort and the error is fixed! Good luck.
Nov 17, 2008 | HP PSC 2355v All-In-One InkJet Printer
Error message: Open door, clear carriage jam and then press enter
Our support works this way. You will receive an email notifying you that there has been a reply to your post, such as this. You read the post, enter your comments in the Comment Text Area Below and you'll get another email when there is another reply.
I will ask you to do one thing, await your response and then give you further instructions.
First of all, with the printer on, and leaving it on, open the cover to the print carriage area. Now, reach over to the right under the cover of the printer and pull the ink carriage to the center.
You will want to use a flashlight to examine the area around the carriage bar for an obstruction. Common items are pencils, pens, paper clips. Additionally, the ink cartridges themselves may not be firmly locked down in place. You may notice this when you reach under and over to grab a hold of them and drag them over to the center.
Should you be able to get this carriage over to the center, check that the cartridges are lock down and nothing is lying in their path on the far right hand side. A flashlight will help you.
Regards,
Worldvet
Nov 03, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
