Question about Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor
My jensen dvd player mvb85
My dvd player used to work fine. when I play dvd's now the sound works but there is no picture. Did I change a setting or did a wire come loose or is the dvd player broken?
  • 1 more comment
  • skane Feb 06, 2008
    the wire is in the roof of my car as it is installed, is it easy to see? It could have come loose? Are there separate wires for sound and video?
    also, I lost my manual. Do you know where I can get or print a new manual?
    jensen 8.5" MVB85. thanks.
  • 146 Answers
I think there are 90% chances of video wire plugged in wrong port... remove the wire from dvd player and tv,, and again plug in after checking your manual. In settings check for ntsc/pal mode, if you have these option, try changing to different mode..
good luck
Posted on Feb 06, 2008
  • Prabjeet Singh
    Prabjeet Singh Feb 06, 2008
    It wont be that easy to check wire inside your car body... you should contact service center of your dvd player...
    for manual, either google, or tell me the exact model, so I can further help you assuming the wires are ok and there would be some problems with settings...
  • Prabjeet Singh
    sorry, couldnt find the manual,, even their website says, they dont have this model in their list.. Funny!!
  • 749 Answers
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Jensen flip out head unit volume knob doesn't work . the remote works fine but just that one problem.. and i cant seem to get the DVD to play.! ( bought it used..)
it needs to be serviced by jensen or some other repair facility. there is nothing you will be able to do to get the knob to work. if it plays cd's and not dvd's thats also an issue that you can't fix by yourself. if it doesn't play cd's or dvd's then you can TRY to run an optical cleaner through it. its a cd player cleaner kit you can get at most electronics stores.
Mar 17, 2010 | Jensen's VM9312 Car DVD Player
It can't read dvd disc, but if i'm using an mp3/cd its fine
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
Nov 05, 2009 | Jensen's VM9312 Car DVD Player
We bought a used car with a Jensen overhead mount dvd player in it and I'm trying ot get the audio working. The car came with 1 audiovox wireless headset and that's the only way we can hear it though I see...
2 WAYS FOR SET UP.
IF INSTALLED THERE IS A ON/OFF SWITCH SOMEWHERE IN DRIVERS REACH THAT WILL TURN ON A FM MODULATOR. THEN TUNE TO A CHANNEL ONE BY ONE TILL YOU HERE DVD MOVIE SOUND.
ONCE YOU FIND THAT CHANNEL LOCK IT IN.
SECOND SET UP.
THE MENU ON SCREEN MAY HAVE SOMETHING THAT MAY SAY "FM MOD"
MAKE SURE IT'S ON AND THAT MENU WILL HAVE AN OPTION FOR SELECTING AN FM CHANNEL.
TRY IT OUT.
Oct 10, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Dvd player is not reading discs
hi, i took the whole thing apart and i noticed the laser wasn't coming on, so i found where the laser is connected to and the connection was not pushed in all the way in so i pushed it in all the way, now it works.
Apr 14, 2009 | Jensen 8.5'' Overhead DVD Player Package...
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Jensen VM9020TS car dvd player I get T.V sound but no picture
make sure your TV module is properly installed ( plug completely engaged )
If it is , then I would suggest a reset of the system .
Feb. 15th the TV will stop working anyways... due to the digital change over...
Nov 14, 2008 | Jensen VM9020TS Car DVD Player
DVD playback in black and white
check colour system on both . if u dont know the colour system change it on AUTO.this will solve your problem
Dec 28, 2007 | Jensen TS2050J 20" TV
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor Logo
379 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
