Question about Cerwin Vega LS-15 Speaker
How do u connect speaker wire
I have no idea how to connect speaker wire. to techwood stereo system. no sound comes out.please email me whispr27@yahoo.com
Are your coponents plugged in and make sure you play a cd when doing this so you know you got contact is it dj equipment or standard
Posted on Feb 13, 2009
    Master:
    Sergeant:
  • 440 Answers
Use ch a only on tech postive + on + _ on _ black ect only ok use ch a only if ch a ddont work try ch b only sel in front ok not both
Posted on Feb 04, 2008
Speakers stopped workin in a 2000 Suburban
If you have a non-original stereo, there may be inline fuses in the wire harness leading to the stereo. Look under the dash with a flashlight and see if you can find the harness. Alternatively, you can pull the stereo from the dash and look at the wires that way.
The speakers can be checked by using a 1.5 volt battery. Unhook the speaker wires from the back of the stereo. Then, using jumper wires, MOMENTARILY connect the battery to each pair of speaker wires. If the speaker is good, you will hear the speaker cone move (it will make kind of a scratching noise) as the battery is connected.
If the speakers check out, and you are SURE that the stereo is receiving power and ground at all the correct points, then I'm afraid that your stereo is likely damaged.
Jan 05, 2014 | Chevrolet suburban player. stereo...
How can I listen to audio from Techwood TV/DVD player through home stereo? I have connected a red&white stereo lead & selected aux on my stereo, but sound still just comes out from the TV. Any help is
Make sure that you are using the Audio Out ports (not one of the audio in). Next go into the menu. Select the Audio setup option and see if there is a line for enabling the external speakers. (Often this corresponds to turning off the internal speakers but not always.)
I hope this helps. I'm not familiar with the specs of Techwood TV models. Some TVs only have an headphone/earphone (3.5 mm) jack as their audio out. In that case, you'll need an adapter to convert the RCA audio to the headphone jack.
Dec 09, 2011 | Televison & Video
Ive got these speakers and a real high pitch noice just started coming out of them
hello, This can due to loose connection in the stereo cable (broken wire). and also do you have earth wired to the system or the output device? This is how to check a broken wire, just simply remove the stereo jack coming from you device or PC. make sure you remove both ends, see whether the sound is gone. if you don't have a earth wired, please use a proper three pin plug. if this doesn't work, you have problem with the sound amplifier inside the sub-woofer.. you need a repair :(
Feb 16, 2011 | Altec Lansing ADA995 Speaker
Speakers have no sound coming from them.
There is not fuse for the speakers themselves. The speakers maybe blown out. I would take a speaker out and connect it to the home stereo and see if it works. I would check to see if the speakers are plugged in also.
May 01, 2010 | 2000 Volkswagen Jetta TDI
Can I connect a Computer to a Techwood DDR 94 AV Digital Surround Receiver so that I can listen to radio stations online?
Yes. You can. First, you need a cable that has a stereo pin called stereo jack (the type that has on ear phones/head phones) on one end and component cable terminals (the type that comes with video/ audio left and right) on the other end. To further explain, these terminals come in yellow red and white colors. You only need the red and white ones. This is available at electronic stores. Otherwise a person who service electronic equipments can easily make one. Basically, this cable will have a stereo jack (small one) on one end and split into 2 cables with the red and white terminals. Once you have this cable, connect the stereo jack to the ear phone socket of your computer and connect the other end to the audio input of your Techwood receiver. You can select anyone (CD, DVD or TV). These inputs are right above the speaker wire connections. Be careful to connect to the socket that say "in" . Now, let us assume you have connected to the CD, select your source as CD on your techwood receiver. Play music on your computer and you should be able to hear the output through your Techwood receiver. Good luck
Apr 05, 2010 | Computers & Internet
Speaker wire tabs for neg/pos connections in rear of speaker
The usual spring-loaded speaker terminals can be bought from constructor supply catalogues or salvaged from broken or obsolete equipment.
It should be possible for anyone with a moderate practical aptitude to replace the terminal if the original is beyond repair. It is a largely intuitive process.
Mar 14, 2017 | AAD E-30 Main / Stereo Speaker
Problem w/ Panasonic SA-HT700 speakers
Try looking in the audio settings,it might be configured for stereo/mono or any number of surround sound settings e.g; 5:1, 7:1 In which case it might shut off the power to the circuit board inwhich the speakers are connected.If that fails .......Take it back!! Either the connection inside the speakers is faulty or the connections in the unit are faulty.
Oct 25, 2008 | Panasonic Home Theater System System
Techwood DDR94A stereo
i found the manual to the Techwood DDR94A at diplodocs.com
Apr 08, 2008 | Audio Players & Recorders
Techwood 400 watt Stereo Receiver PLR85
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
Cerwin Vega LS-15 Speaker Logo
438 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
