Left Deck Door Stuck Shut on Cassette Deck
I just put a cassette tape in the left deck. The cassette player made some funny sqeaky and clicky noises, and refused to play the tape. I tried to remove the tape, and now the door is stuck. Without breaking the door off, how do I open it to remove my cassette?? Help, and thanks!!
  • 2 more comments
  • old Cassette Apr 01, 2008
    Both doors on dual cassette stuck shut with tapes inside. Won't play tapes either. Phoned Panasonic who said to unplug the unit for 20 seconds. Didn't work.
  • koda1953 Aug 24, 2008
    I had the same problem on a Sony TC-WR635S, tried the wheel rotation, then the wheel wouldn't turn either direction once it rotated to a stop one way. Then I took a good look at the cassette tape that was stuck and noticed something like reflective cloth in one of the two holes at the bottom of the tape. Yep, it was tape wrapped around the capstan. On this Sony deck, if you can get the door to open just a bit, the door cover will pop off if you lift up on it gently on both sides. I removed the door cover, pulled the tape out from around the capstan in little pieces, then the door came open like normal. Problem finished. The tape had prevented the cassette from sliding out, thus keeping the door closed. I think this should be the first thing anyone looks for when a cassette door won't open.
  • Anonymous Oct 10, 2008
    I don't really know the correct name, but I think tape deck is correct. I wanted to review some footage and as soon as I pressed rewind it said please remove tape. When I open the hatch that covers the tape deck, ect. the tape deck didn't even make an effort to open. I hear the noise signaling the camera registers that I opened the hatch. This is on a Canon GL2. I can't ruin the tape because this is valuable footage
  • dharapatel91
    dharapatel91 Jul 20, 2012
    The dorr will not open at all
  • 579 Answers
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Neither of my soni rx88 cassette deck, A or B is
The little brown wheel... Do you mean the rubber idler pulleys that are brown because they've never been cleaned? If they fell off they'll need to be replaced properly by a tech.
Apr 30, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Dec 25, 2008 | Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
2,651 people viewed this question
 Grubhead
Grubhead
