Question about Onkyo TX-8522 Receiver
How connect subwoofer to onkyo 8522
No sub out jack on receiver. Just bought a Polk sub with line in/line out connections. Do I run one set of speakers from the output of the sub? Any other suggetions?
  • eichelberger Feb 13, 2008
    not sure I follow...so I can connect the front speakers through the sub. i will try that this PM; may need more help with adjustments to the sub even if I get this signal through. Thanks
    Master:
    Sergeant:
  • 440 Answers
Does it have speaker wire in and out use then from fronts
Posted on Feb 04, 2008
How do you connect a Jamo sub250 to a Onkyo tx-sr343 av receiver
You simply connect a RCA type line cable from the subs line input to the dedicated socket on the back of the Onkyo.
When you run speaker set up it will set the subwoofer up.
Jul 11, 2016 | Jamo "SUB250 250 Series Subwoofer, Single"
I have a polk subwoofer and I want to know hot to connect it to my onkyo Lst10 surround sound bar
There should be a input for powered sub on bar, will have black input, and be labeled. Or check your reciever for sub output.
Dec 12, 2014 | Audio Players & Recorders
I have a true sunfire sub and an onkyo 703 that has an rca connection for the sub. My question is do I connect my side channel polk 65's directly to the sub in jacks or directly to the reciever? If
The input jacks on the subwoofer panel are for connection of satellite speakers to it's crossover. The outputs are for the crossed over signal input to your receiver or amplifier, as there will be no amplification or channel processing from the subwoofer connection. It's only an optional crossover that may have a sonic advantage over the crossover in your receiver.
What you also can do is connect the speakers directly to the 703 and set the crossover frequency on it.
Dec 07, 2011 | Sunfire True Sub MK II Subwoofer
How do you connect a sub woofer to a Onkyo TX-8522?
Since it does not have a dedicated subwoofer pre-out, you would have to use the "TAPE" outputs. If your powered sub (I'm assuming your using a powered sub) has only one input, you could either just use the left tape out of the receiver, or use an rca splitter to convert the left and right to a single jack. (I'm not a fan of that method, though).
Jul 01, 2011 | Onkyo TX-8522 Receiver
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
Subwoofer not working on onkyo tx-sr600
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
HTH
Jan 16, 2009 | Onkyo TX-SR600 Receiver
No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Jan 06, 2009 | Onkyo TX-SR703 Receiver
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-8522 Receiver Logo
439 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
