TOSHIBA TP55E51 BROKEN FRONT SCREEN
My kid broke the thin front screen layer of my tv. I know the pice is removable but would i be able to purchase a new one or have it repaired
    President:
  • 4,402 Answers
Can not be repaired has to be replaced.
Posted on Feb 04, 2008
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
My htc tytn II touchscreen is not working.
Possible failure of the touch screen or the main board. But since this job is adviced to be looked into by the company specially if spares are required, the opttion to remove must be reconsidered.
Try and warm up set to confirm if any moisture set on has resulted in the prroblem.
Sep 19, 2010 | HTC TyTN Smartphone
Can i cut another screen to fit my tv?
depends on what type of screen you have and if you want to cut the protective layer or the actuall screen which on some tvs is 2 layers of thin glass with liquid in between. in that case no but if you just want the outer case then yes just cut it out of plexiglass or another thin transperent material.
Sep 16, 2009 | Toshiba 50H82 50" Rear Projection...
I have a sony lcd kdl-52w3000 and it has 2 large circles on the left side of the screen(it can also be seen when the tv is off) and it has 3 small ones on the botom of the screen.
Seems front screen layers got some dust or some thing that you see as big circles.
Need to apart front bazel assembly of TV, remove front screen and clean it carefully because it can be broke easily.
Aug 11, 2009 | Sony Televison & Video
My screen accidentally got broken but TV was working fine...is there a way to get a replacement screen? can I buy the materials to do it myself?
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
4-090-881-11 SCREEN (57), CONTRAST (KP-57WS510 ONLY)
4-095-924-11 PLATE (57WL), DIFFUSION (KP-57WS510 ONLY)
4-081-950-11 PLATE (57WFV), DIFFUSION (KP-57WS510 ONLY)
Also check HERE for your TV screen.
Aug 04, 2009 | Sony KP-65WS510 65" Rear Projection...
Re-install TV screen
yes my friend, just pull hard on one of the sides and the front housing start to come off
caypianan@yahoo.com
Oct 12, 2008 | RCA HD52W58 52" TV
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
Touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Sep 30, 2007 | Garmin StreetPilot 2720 GPS Receiver
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
