Question about Dryers
Gas dryer Model MDG9316AWW does not always ignite
The burner ignites and stays lit for 2-3 minutes and then does not come back on again. However, the drum continues to turn for long periods of time on the Auto Dry settings.
  • Anonymous Jul 17, 2008
    My dryer has two thermostats. Which one the cycling or the high limit would cause this issue?
  • mesmoyer Mar 15, 2009
    my dryer makes a squeeking noise on start but that goes away after about 1/2 minute
  • 549 Answers
First check the exhaust vent to the outside do you have a strong flow of air?
Is the lint passage free of lint? Are the blower vanes clear of lint?
A simple test for the sensors, bypassing the wires to the thermosensor and operating the dryer to test. If the heat now stays on the sensor is usually bad. Also if the flame backs up the safety thermo can kick out to protect against fires. Usually due to plugged lint somewhere.
Posted on Feb 05, 2008
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
I have a Maytag gas dryer Model number LDG 9800 My problem is the burner will light and stay lit for about one minute and will go out.Then after about a minute or so The igniter will come on but the...
The gas valve coils are going to be the problem..its a fairly common problem with gas dryers and this is what to do to fix it...this link http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while is what i wrote to answer it. To save my tired old fingers from typing the same thing again i have copied and pasted it.
Gene
Aug 21, 2011 | Dryers
I have a Maytag gas range model MGR 5729 ADW. My problem is this: 1. The igniter glows brightly 2. Burner will light with a strong woosh, but not until 2-3 minutes. 3. Burner goes out after about 30...
get in a gas fitter to properly diagnose the problem,
igniters in ovens normally click / flash as that ignites gas quicker than a hot wire so I suspect that is problem 1
problem 2 indicates that there is a gas flow problem, probably a faulty hose or regulator
what ever it is , gas is not in the domain of diy so an accredited professional gas fitter is required to do the fix
Apr 25, 2017 | Kitchen Ranges
Burners won`t stay lit.........
There are several possible causes for this. Bad flame sensor, bad thermostat switch, blocked air vent, or bad gas coils.
This website
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Has very good troubleshooting and repair information for all of the possibilities
Feb 02, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Lga30aw burner won't stay ignited
The gas valve coils are weak and must be replaced.
Jan 17, 2010 | Amana Dryers
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
May 03, 2008 | Dryers
Dryers Logo
427 people viewed this question
Top Dryers Experts
