Brother 7820n
How can I get in to service mode?
    Scholar:
  • 78 Answers
User maintenance mode is -
Menu/Set
, Start, Menu/Set , and keys in this order
The function you can change are -
06 Placement of CIS Unit Position for Transportation
09 Test Pattern 1
10 Firmware Switch Setting
11 Printout of Firmware Switch Data
12 Operational Check of LCD
53 Received Data Transfer Function
54 Fine Adjustment of Scan Start/End Positions
80 Display of the Equipment's Log Information
82 Machine Error Code Indication
87 Output of Transmission Log to the Telephone Line
99 is to exit.
Posted on Feb 05, 2008
6ya staff
SOURCE:
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Our Brother 7820N all of a sudden started paper jamming. Took everything out and it still jams. What can I do.
Try the link below, if its not working that may be a hardware issue and needs repair: 7820n Paper Jam
Aug 26, 2010 | Brother MFC-7820N Laser Printer
Brother 7820N has black vertical line when using ADF
It's the same scanner ccd, after you make sure the narrow scanner window is clean, you need to power down the machine and power up again so it will calibrate to a clean window, if it has a scratch like from a staple, you will need a new glass.
Jan 18, 2010 | Brother MFC-7820N Printer
Find a printer driver
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_index.html?reg=us&c=ca&lang=en&prod=mfc7820n_all&type2=1&os=26&flang=English&dlid=
Hope that helps.
Jun 09, 2009 | Brother MFC-7820N Laser Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at [email protected]:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
MFC-7820N Printer Problem
If you haven't done so already, download the drivers for the printer from http://www.brother-usa.com/Downloads/Default.aspx and install them. Ensure that the printer is properly connected to the computer (typically via a USB cable for most newer printers).
Brother also offers email support at: http://www.brother-usa.com/AskUs/default.aspx
Oct 13, 2007 | Brother MFC-7820N Printer
164 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
