Question about Kenmore 98702 Stacked Washer/Dryer
Model 417.94802301 stackable with electrical haywire?
My stackable washer-dryer recently quit. The breaker in house electrical box had shorted out and was replaced. NOW dryer comes on but does not heat. Washer will not come on unless dryer is on and then after tub fills with water it does not progress to agitating. If dryer is turned off while washer is filling, washer stops. I currently have a tub full of water and clothes and Sears can't come out untill February 18th. Help! Can I tackle this myself and, if not, what might I expect from Sears when they do come out in addition to the $64 house call charge? Thanks.
  • Anonymous Mar 27, 2014
    GE pops house breaker not stackable unit breaker
    President:
  • Kenmore Master
  • 2,651 Answers
You got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Posted on Mar 10, 2008
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a kenmore stackable washer/dryer. The dryer spins but does not heat. I looked at the owners manual and it states that one of the house fuses needs to be replaced. Where are the house fuses...
Hi jahusmc...
To find your house fuses/breakers look for a box that is mounted on a wall within the house.
It will have a metal door on the outside and will contain all the electrical circuts controlling the house.
Once you locate the main breaker box, look for a breaker in the box that looks "out of place" with all the other breakers, if you find one, recharge it by pulling/pushing on the toggle of the breaker to reset it. Once that is done you should have voltage again.
The easy way to see if you have voltage at the plug is to use a volt ohm meter, check the receptical for the correct voltage either 110-120 volts or 220 volts depending on what your dryer uses.
Please take time to rate me
Aug 29, 2011 | Dryers
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Dryer shorts out some of the electrics when its switched on!
The breaker in your breaker box is either weak and need to be replaced or the amps is too low. But from what you stated, you have had this dryer for awhile, so I'm assuming that its just a bad breaker. If the dryer still runs and doesn't have any issues when it dosn't pop the breaker, then this is what it is. Have an electrician come out and replace the breaker if you are not familiar with doing this.
Apr 10, 2009 | Tricity Bendix TM310W Electric Dryer
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 | Dryers
We have a kenmore dryer model 11082182200 (stackable) breaker blows when plugged in. Not sure where to start looking for the problem.
If the breaker is turning off when plugged in the dryer has a direct short somewhere. It could be anywhere inside the dryer and the dryer will need to be disassembled to find the electrical short. Leave the dryer unplugged and get a test meter to help locate the problem. I will be here if you need, just let me know, Thanks, Sea Breeze
Mar 21, 2009 | Kenmore 63942 Dryer
Neither my washer or dryer has any power on our electric stackabl
IT IS GOOD THAT YOU STARTED WITH THE HOUSE ELECTRICAL. I WOULD NOW CHECK THE POWER AT THE RECEPTACLE AND THEN TAKE THE COVER OFF THE BACK OF THE MACHINE WHERE THE CORD CONNECTS TO SEE IF MAYBE A WIRE IS BURNT OFF. I HAVE SEEN THIS TOO MANY TIMES TO PASS CHECKING THIS.
Jan 26, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
798 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
