Question about Manfrotto 055NAT3 Tripod
ART055 manfrotto pro tripod
I am looking for a lever to lock the upper leg section in place as mine has snapped off. Any ideas?
    New Friend:
OK so I had the same problem broken white metal handle on a Monfroto 055 leg clamp. Basically these leg clamps are just quick releases. So I removed the plastic cap oposite the handle removed the nut underneath and that let me pull the remains of the leg clamp out. Then I found a quick release in a box of parts that I keep and installed it. I don't know what the quick release was from (not a bike wheel that would be too long and I don't think it was a bike seat because I think that would be too thick). I dropped two Pirelli tube nuts into the inset where the nut for the Monfrotto quick release used to sit and that kept the new quick release nut up where I could get a wrench onto it. Tightened it into place and voila; as good as new. Except that of course there is one mismatched handle on my tripod. But I can live with that.
Posted on Oct 26, 2013
    Sergeant:
  • 201 Answers
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Posted on Feb 04, 2008
6ya staff
SOURCE:
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Nov 07, 2012 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
A couple of the lever locks on my Manfrotto 055XB tripod are no longer sufficiently locking the legs so they slip. How do I tighten them?
Use an 8mm, I believe, socket and tighten 1/4 turn the nuts on the lower half of the leg lock. For instance, the top leg lock is connected to the top and middle leg. Tighten the lower 2 nuts (located on the middle leg half of the lock) 1/5 turn. If that does not do it, tighten 1/4 turn again. Be sure not to over-tighten.
Aug 10, 2010 | Manfrotto 055XB Tripod
Locking tripod leg
Sorry, the mechanism and how it is put together should be repaired my Manfrotto. It has a one yar warranty when you bought it, and if you went to the Manfrotto website and registered it then the warranty is 3 years.
Jun 09, 2010 | Manfrotto 458B Neotec Pro Photo Tripod...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
I have a nice manfrotto tripod and one of the snaps on one of the legs no longer works, so the tripod now slouches on one leg. Is it worthwhile to repair it, or do I just need to buy a new one? I paid...
If the leg lock is still there in one piece, should be no issue. If you notice, the leg lock covers bothe an upper part of the leg and a smaller diameter lower part. Take a socket (8mm if I remember corectly) and barley tighten the nits on the bottom half of the locfk. Loosen and tighten nuts until rasing and lowering leg is no issue.
Jan 10, 2010 | Photography
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Manfrotto 055NAT3 Tripod Logo
338 people viewed this question
Top Manfrotto Photography Experts
ray gallant
ray gallant
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
