Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Wd 120gb External no longer recognised by my PC
My USB WD Exteral Hard Drive was installed by Windows XP But it is no longer displayed in MY COMPUTER please help
  • 5 more comments
  • stantin Feb 05, 2008
    Thank you for suggestions. I think perhaps that I did explain the problem sufficiently. I have used the USB WD 120gb external Hard Drive and it initially installed correctly. I had reason to uninstall the content and there now seems to be something missing. I am told that it is working properly but the My Computer Icon and other detail is Missing so I am unable to use it.
  • Anonymous Mar 05, 2008
    As you explained in the above. It has worked befor and now it just does not work. My pc does not pic it up and I can not do anything with it.
  • trongkien May 07, 2008
    I had the same problem. My USB WesternDigital Storage 80G did not work with my computer. But when connect it into other computer, it works normally.
    My computer even did not recognized it, no alert, no notice. Please help and email me. Thank a lot!
  • Jucfel May 18, 2008
    Same problem with my WD. It just happened. I hope there is a solution other than buying a new hard drive...PLEASE HELP
  • Anonymous May 22, 2008
    CAN'T SEEM TO GET IT WORKING
  • segovia58 Jul 23, 2008
    i initially bought the WD 120gb to transfer files from my desktop (windows ME) to my laptop Vistas.
    it works fine when plugged into the laptop, and IT DID run fine the first couple time i plugged it into the desktop.
    Now the desktop doesn't recognize the drive.
    i tried several times plugging/unplugging to no avail.
    i realize that the device is bus driven and not enough power delivered may be the problem...but then again....it did initially work 4 or 5 times before it was no longer recognized.
    Suggestions most welcome.
    Bob
  • jecster Jul 28, 2008
    same problem. windows xp no longer recognizes my WD. tried to connect on a mac, still nothing.
    all my files are in the WD. help please.
I can see that I was experient the same problem with my WD external.
I keep on unplug it but it doesnt show on my computer.
So now its show on my computer by doing the plug in on external on this way
Follow this step carefully
1. Plug in the power chord to your external(don't plug in the usb yet to the computer)
2. Plug in the end on the usb to the computer
3. After 10sec plug in the other end of the usb to the external Hard Drive.
Wait there for about 5 min depent on the speed of your computer to regonise the external, than you can see a file autoplay showing loading your external drive content.
After its load you can check on my computer the drive shows there
Hope this will help
A.Abba .Finau
Tonga
Posted on Jan 09, 2009
I had the exact same problem. I plugged it in over and over again, deleted the drivers, everything. I plugged it into my laptop and nothing. Then I plugged it in to another desktop and it worked there. I went back to my original desktop which it quit on and it opened! Now it works fine.
Good luck, I had this problem for months.
Posted on Jun 05, 2008
It stile does not work
Posted on Mar 05, 2008
  • 871 Answers
Hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Posted on Feb 04, 2008
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Well my external hard drive( hde6-640g) no longer registers on my computer i get the message"windows does not recognise this usb device" can u help , it is a wd hard drve inside the case.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 08, 2010 | Western Digital Computers & Internet
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
My drive is not recognised on my windows laptop
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Note that W.D. has a "Customer Loyalty" program; buy a new W.D. drive from the W.D. web-site, at a good discount.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
How to tranfer files from WD 1TB exteral hard drive into my computer?
locate these files select them right click copy then paste them into your computer
hope this helps
Sep 18, 2010 | Western Digital My Book Essential 1TB...
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Sep 15, 2009 | Western Digital Elements powered by WD 320...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
My usb ports are limited to 500mA each one and the WD external HD needs at least 1000mA. How can I solve that?
You might need to install a new USB card, one with 1000 mA, to provide the power necesary for your WD external drive. Check the WD manual to see whether there is a way to use two USB ports when jumpering them to see if you can provide the power yourself.
Also check the WD web site.
Jun 26, 2009 | Western Digital Passport 120GB External...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
462 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
