Question about Filter Queen Cheetah II Ash - MU305 Bagless Canister Vacuum
Step Switch replacement
I have to replace the "Step Switch" on our Filter Queen. I need some direction in doing this.
Does anyone know how this is done?
I could just start taking things apart, but I want to do it right and have no pieces left over when I am finished!
Thank you.
  • robk92 Mar 19, 2008
    Well I have kind of the same problem, I have an older filterqueen 1970's, and one of the wires came off the switch and some of the other wire nuts were off. Don't ask me why this didn't short out but it didn't. Do you have a diagram of how the wires should go?
    Thanks
    Rob
    President:
  • 1,673 Answers
Take off the cap on top, remove the 3 screws, then the top comes apart and you can get to the switch.
Posted on Mar 15, 2008
How do I change the power cord on my Filter Queen vacuum cleaner?
First, remove the top filter cap. quarter turn.
Remove the three screws from under said cap.
The rubber switch cover will come off of the on/off switch pedal there. pull off and set aside.
undo the two clamps and remove the motor (chrome) section from the base.
give the handle a tug and the chrome cap should now come off and allow you access to the wiring and motor/switch.
optional side note: at this point you may want to replace the sponge filter around the motor too.
Remove the cord from the unit and rewire to the same spots the old cord comes out of.
reverse the instructions to put the machine back together.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
I just purchased a tune up kit for my filter queen, how do I replace the dome cap pad? I can see it but I dont know how to get to it.
I was trying to replace the silencer filter, we had to take the dome cap off and remove the screws by the sn plate then lift the top off. It looks like the motor has been replaced at some point (I purchased this one used) so the wires had wire nuts holding them together. We had to separate the wires for the light so we could remove the old filter and install the new one.
Feb 06, 2010 | Filter Queen Majestic Canister Vacuum
There is very little power and lots of sparking from the brushes on a Filter Queen motor out of Model 95.
Your motor needs major work. The brushes are probably the cause. My presumption is the armature is burned.
You may be able to get a replacement from Filter Queen and it is worth a e-mail to them.
Alternatively, you might find a replacement at a Fixya.com advertiser or at www.repairclinic.com
Oct 22, 2009 | Filter Queen Majestic Canister Vacuum
Motor Brush for older model Filter Queen
Is there a Johnstone Supply in your area? How about an ACE Hardware. A vacum repair place? Sewing machine repair place?
If you have the data, ACE or Johnstone should be able to help you. Don't discount other electrical supply places. You will not get help at a big box place.
When I Googled "Filter Queen parts", I found lots of places on the WWW. There must be something close to you.
Give it a try. Let me know if this works for you.
a
Sep 21, 2009 | Filter Queen Cheetah II Ash - MU305...
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
My filter queen majestic needs help
Try replacing the belt. It's not a difficult procedure, just unplug the machine, turn it over, remove the two screws which hold the chrome plate on and you will see the belt. Take the roller brush out by pulling up on one side, then remove it from it's housing. Then you will see what will probably be a worn out belt, rough on the inside and stretched. Replace the belt making sure to rotate the roller to ensure proper alignment. Then replace the chrome plate, and plug it in.
Oct 22, 2008 | Filter Queen Majestic Canister Vacuum
Filter queen majestic
Has the cone filter been replaced?
Do you know how to check the grey filter which is inside the cover where the cone filter goes into/
Jun 09, 2008 | Filter Queen Majestic Canister Vacuum
Oil
Guess I don't understand what you are asking, The Filter Queen vacuum doesn't use oil.
Mar 12, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Cheetah II Ash - MU305 Bagless Canister Vacuum Logo
141 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
