Question about Lexmark X3480 All-In-One Printer
Inccorect cartrigde lexmark x3480 keeps showing inccorect cartridge even when the orignal cartridge is put in
  • Anonymous Mar 16, 2009
    lexmark x3480 keeps showing inccorect cartridge even when the orignal cartridge is put in, help
Go to this link, download file and follow instructions, it worked for mehttp://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=227:5:0:570:0:0&framed=&docid=ENUS25374&relevance=1
Posted on Feb 09, 2008
    Scholar:
  • 103 Answers
Try using a pencil eraser to clean the gold contacts on the back of the cartridge. If they get dirty or cruddy, the printer won't be able to 'read' the cartridge correctly.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Posted on Feb 04, 2008
6ya staff
SOURCE:
Lexmark x3480 catridge incorrect
It could be faulty cartridge issue. Try to replace a new genuine cartridge to determine if the other is faulty.
Mar 16, 2012 | Lexmark X3480 All-In-One Printer
Hi, my printer keeps saying cover open even though it is not have opened printer up but do not know which way back to put the white piece thanks
Remove the sheets of paper. Open the printer cover and remove the cartridges as well. Close the cover. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Load some paper. Check for any error. Try to print.
Apr 11, 2011 | Lexmark X3480 All-In-One Printer
Screen says 'incorrect cartridge' Lexmark X3480 cartridge fitted
The only cartridge that fits in your printer is the 18C0788 #1 cartridge if you have put another cartridge into your printer that is not the #1 cartridge I recommend you remove it and replace it with the correct cartridge.
Jun 03, 2010 | Lexmark X3470 All-In-One InkJet Printer
New cartridge fitted still reads low ink.lexmark x3480
Try this... Unplug the printer from power and restore power... also, reboot the computer. if that doesn't work, try reinstalling the cartridge or reinstalling the software. If there is an option to ignore these messages, it will be in the options srction of your printer manager program.
Dec 29, 2009 | Lexmark X3480 All-In-One Printer
Lexmark x3480 cartridge missing fault
First make sure that the refill cartridge is the correct one.
Example: X3480 printers: #2 cartridge
If so than take the cartridge out and clean all the contact points with a dry cloth. These points can sometimes get dirty, especially by refilled cartridges. reinsert the cartridge and than unplug the printer and plug it back in after 10 seconds.
I can type out how to troubleshoot this, but it would be easier for you to open the link below. This will give you step by step instructions on how to do this.
http://support.lexmark.com/perl/support/support.cgi
Let me know if this does not work for you. Good Luck!
Mar 13, 2009 | Lexmark X3480 All-In-One Printer
X3480 printer.message is saying;cover is open
the meaning of cover is open means --------the cover means.the thing which you lift to remove or install the cartridges.just keep that cover closed.if that cover is closed still its showing the same error.then the sensor which detects the cover closed is got moved from its orignal position.to reset the sensor just tap all the sides of the printer for couple of minutes.mostly the top side and front side of the printer.and then check out the error must go away.if still the same error then its quite possible that sensor is broked as it very very delicate .so it needs a technician to replace the broken sensor.the cost to replace the sensor must not exceed then $5.
Feb 26, 2009 | Lexmark X3480 All-In-One Printer
Lexmark x3480 cartrige incorrect message
I had the same problem. Downloading and running the patch program solved it for me. Follow the link below!
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:570:0:0&docid=ENUS25374
Regards Robin
Oct 31, 2008 | Lexmark X3480 All-In-One Printer
Ink cartrigde
Did you remove the protective blue tape from the cartridge bottom, if please clean the cartridge Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if you still have the problem you can contact lexmark and get the cart replaced with a new one as the cart comes with 6 months warranty.......
Jun 30, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark X3480 All-In-One Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
