Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor range Does the convection fan work when the reset switch is depressed. I have a range and when I set the temp and function, I can hear the relays clicking but no power going to the elements. Will the fan still work if the no power to the elements Could this reset switch be the problem.
  • In the Cold Jun 10, 2008
    I have removed the front panel from the circuit breaker box and measured each side of the power into the stove. Each side measures approximately 124 volts. Resetting the breaker does not help.
    Genius:
  • 1,665 Answers
6ya staff
SOURCE:
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My Samsung gas range model NX58H5650 was converted to propane. The convection fan does not work.
call a technician as it will be an electrical problem
the fan should start as soon as the oven is switched on or if on a separate panel switch may require you to switch it on
Jul 04, 2016 | Samsung 5.8 cu ft Freestanding Gas Range...
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Bake and Convection preheat abort after a few minutes
Hey Jeff Bassler,
How about... Instead of such an expensive experiment
You have a look at some related scenarios cited on
applaincepartspros... My concern is not getting fault codes.
Sorry:
I would need to know your service HISTORY...
SPECIFICALLY: Did this unit ever work?
(to disregard the notion of a FACTORY wiring error)
((proper trouble shooting = ASSUME NOTHING)).
Convection Q&A
http://www.appliancepartspros.com/whirlpool-relay-brd-sheild-12001694-ap4010046.html#qa1
Also see support video (page bottom - same URL)...
Jul 12, 2017 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn-aire s176 electric oven will not hold set temperature
Sounds like you have a bade temp sensor.Have a great Thanksgiving.
Nov 25, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Convection oven fan keep shutting on and off
You do not list a model number, so I can not confirm this, but I suspect what you are hearing is not the convection fan, but a cooling fan, designed to come on at a certain temp to keep the control area from getting too hot.
Oct 18, 2009 | Kitchen Ranges
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven not heating after self-cleaning cycle.
That did it for me too. You saved me a $200 service call!
Nov 05, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
357 people viewed this question
Top Dacor Kitchen Ranges Experts
Ekse
Axel Gringmuth
Marvin
Marvin
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
