Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Trying to connect new HP Blackbird PC
OK - Existing Dell XPS works fine using DVI to port 5 on the Aquos. Spanking new HP Blackbird PC provides a 'Signal not compatible' message on the TV screen. Question is whether it's a monitor issue, PC issue, cable issue and of course what remedy should I apply !
Help !
  • Ivoryhouse Feb 04, 2008
    That's really hard to do when I can't see any output display.....
  • Anonymous Dec 25, 2008
  • 440 Answers
Try updateing the system pc 1st all latest drivers video ect windows update ok
Posted on Feb 04, 2008
  • nick helpap
    nick helpap Feb 04, 2008
    dont plug it in as u do this onbord labtop screen
No DVI video output from dell xps 210
It sounds like your video card has gone out. Is the VGA and DVI ports on the same video card? If so the card is probably bad.
Mar 25, 2012 | Dell XPS 210 PC Desktop
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
I am trying to connect my Dell XPS one PC to a D link router, but I keep gettingan error message that the ethernet cable is not properly connected.There is only one port and the cable is correctly...
You need to be more specific as far as your layout. On your modem there is only one Ethernet port that needs to have a cable running into your D-Link router's WAN port. Now take a second Ethernet cable and run it from an available port on the D-Link router to your Dell XPS.
You may need to check that you have the correct Network Adapter driver installed. They are a bunch of scenarios that could be your problem. But with the little bit of information you provided, its hard to narrow it down for you.
Feb 18, 2010 | Dell XPS One Desktop PC RED-20" HD...
I have mistakenly changed my wireless network settings on my DELL XPS M1330. I see my wireless router on teh netowrk list but it now has a red x against it and an error message 'the settings saved on...
Look in your icon tray for the wireless device, right click on it, pick connections, highlight your existing home network, Delete it then start a new connection to the same signal and input the password if you are using one. Hint: you will get the same red X if your hard wired network cable is not being used as well. So make you know what the red X is for.
Sep 13, 2009 | Dell XPS M1330 Notebook
My monitor says there is no signal from my new Dell Studio
Try reseating the video card in your new computer. Sounds like it may not be seating in the slot properly. Take it out and put it back in with the power off and then hook everything back up and then see if you get video,.
Mar 14, 2009 | Dell Studio Slim-Tower Desktop Computer
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
HP Blackbird PC Connection 'Incompatible Signal'
You may have the wrong type of DVI, I would try a different cable to hook it up with.
Jan 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
100 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
