Question about Philips 20PF5120/01 20 in. EDTV-Ready LCD Television
20pf5120 have a set that will some times play fine some times only has sound and no picture, can turn on and off and some times picture will come back, but always has good sound. any help?
  • 1 more comment
  • norm  reece
    norm reece Feb 04, 2008
    no the set is on cable tv imput rf, set will work fine turn it off and it may or may not come back with picture, nothing has been hook up or un hooked, can turn on and off and picture my come back on but good sound is alway there when turned on.
  • peachielee3 Aug 18, 2008
    philips 20pf5120 only has sound, no picture. Just a brief flash when turned on, then nothing...only sound.
  • Herseleid Dec 07, 2008
    I have the same problem, when turn On, only de Led Power turn green, but onlycan see the image for a few seconds, (2-3 Second) after only can see a little blurry shadow, but the sound is good.
    I tray all kind of inputs have, and nothing.
  • 8,596 Answers
Are you connecting the tv to your source using the DVI, component (Red Green Blue + 2), or composite (Red, Yellow, White)?
Try switching the type of connection you are using. If you are connected via component, then switch to composite. If the problem persists even on composite connectors, then the issue lies with the TV. If the composite cable works fine, then the problem is most likely the cable you are using.
Press the sleep button, and make sure the sleep timer is set to OFF.
Unplugging the TV from the wall outlet resets the TV.
If you have a cable or satellite box connected to the TV, then try resetting the box also by turning off/unplugging from wall outlet.
Surge protectors can cause some occasional anomalies with LCD TV's (they're still a good idea) - just reset the TV to clear up these anomalies.
-Tha Mp3 Doctor
Posted on Feb 04, 2008
  • Corey Knoettgen
    Corey Knoettgen Feb 04, 2008
    Just to clarify - I didn't mean that anything had been connected or disconnected. I just mean that the RF cable might be bad. We can check to see if this is true, by conencting the cable box to the TV with a different type of cord other than RF.
    -Tha Mp3 Doctor
I wonder if there is anyone that can tell me why Haier 32in.flat screen tv just shuts down and the is still on but no sound or picture is showing could someone tell me what the problem is ?
Sounds like the power supply board is going out on it. I'm a t.v. repairman and many times, I just replace the capacitors on the power supply board and they work great. If you aren't qualified do not attempt this yourself. High voltage will kill. Not worth it, take it into a shop.
Jun 14, 2017 | Haier HL32D2 32 in LCD TV
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
Loud schreikin noise and cuts off.
it sounds as thought the main-board of the TV is arching or shorting out. This is due to a faulty component in the power section of the TV . It is about to completely go out.
The main board need to be checked for bad components.
Apr 23, 2010 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Actually Philips 20PF5320/01 Fault no power, blinking LED
ok you have defective power supply! from the secondary power supply! or hot side.
Oct 08, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips 20PF5120/01 20 in. EDTV-Ready LCD Television Logo
317 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
