Question about Refrigerators
Fridge noise 1) Will make a loud noise, like something is stuck in the motor or possible in fan (if there is one) . Once unplugged for a minute, back to normal. 2) Recently started to make small noise when ever motor is running, almost like a fan belt is going out on a car. Samea s before, unplugging stops noise. I don't want a fire to start, should I be worried? Bought model ED5GHEXNB00 2 1/2 years ago.
  • rmcansino Sep 30, 2008
    motor or fan making noise sometimes turn the dial to turn off motor and it goes away but once i put dial back up it starts again
    Scholar:
  • 64 Answers
Some larger refrigeration units have fans, but typical domestic ones usually do not, only inside the fridge/freezer compartment as such, and is used to force cold air inside the unit to help keep the contents cold.
As for the fire risk, anything electrical usually have a certain amount of risk as far as fire hazards are concerned, but certainly a lot lower then say an electrical heating element or similar device.
The noises you describe usually come from the pump itself, and i can not say if your particular fridge would have any type of fan on it not knowing the model, makes it very difficult to give any sort of prognosis - based on specific models and their typical faults/noises.
Unplugging the fridge simply stops the pump, and the noise usually returns in a minute or two as you have described, simply because the fault/noise is still there.
Pumps and repair work can be expensive, especially if the fridge is an older model and based on the average that most electrical units have a typical lifespan of 1 - 5 years depending on the quality of manufacture.
Look at it this way, a good basic unit costs anywhere from $800 - $1,500 and some of the more expensive models start from around $1,800 + ( Prices are based on Australian models and are quoted in Australian dollars )
Ok so lets break this down a little, i buy a new fridge for $1,000 and it lasts approximately 5 years, this is not expensive if you look at the cost per year which is approximately $200 / year.
Compared to the cost of repairs, typical service has a call out fee, plus parts and labor which can run into literally 100's of dollars. I guess what i am saying here is, they do wear out in time, due to fair wear and tear, and planning to buy a newer one every few years, is not such a bad idea - considering when you weigh up the possibilities of having purchased a device that can keep food cold for up to 5 years ( and in some cases longer ) for around $200 / year, planned replacement models make sense in the long run. A good way to know, is by looking at the warranty and plan to have a newer one to replace it within 12 months of the warranty's expiration, with the added bonus, you can now plan to sell the one you currently have for a few hundred dollars to help with the cost of getting a replacement.
Trust this helps you out a little, and please take the time to rate this answer, thank you.
Posted on Feb 05, 2008
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge makes very loud noises when door is closed and motor is on. When the door is opened the noise stops. It sounds a bit like machine gun fire or the motor is about to give out. Do you know what the...
Initially, would suspect the evaporator fan blades hitting something or a misaligned vent. Pls post back the make & model.
Other areas to check would be:
  • loose covers, flaps or anything outy of the ordinary;
  • compressor support;
  • condenser fan (at the rear) if present;
  • anything else that could be checked visually.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Evaporator Motor & Fan
hi,
you can try to completely defrost the fridge by unplugging it for a day and put you groceries in another fridge, sometime ice dams build up in those and freeze next to the fan blades and cause alot of noise, if its squealing, then its the motor for sure, evaporator motors are usually pretty easy to replace once you study where its at, usually the whole top or bottom and back of freezer has to come out then the motor and fan are right there, keep the fan blade assembly because you put that on the new motor, be extremely careful once you have the bottom and sides out because the coils will be vulnerable to anything if you hit them go to www.sears.com and go to parts area, theres a sears repair store in our town , hopefully in yours or just call around, dont forget to unplug it! hope that helps
J
Jul 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool Refridgerator Noise
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Dec 26, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
64194 Daily LOUD running noise
Unplug, and take cardboard cover at bottom off using 1/4 nut diver. Look at the fan; is there anything touching it? Spin it with your finger. Wait a few minutes then plug back in. Is it comming from the roundish black thing the size of a basketball? If so its not worth fixing?GOODLUCK>>>
Dec 17, 2007 | Kenmore 64192 / 64194 Top Freezer...
Loud Fan
Alex Your fridge has two fan motors: evaporator fan located inside the freezer behind the back panel and the condenser fan motor located next to the compressor on the back of the refrigerator. What fan are you talking about? Give me the complete model number of your fridge and I'll find the part number, location and price for you. Gendos, post back...
Jun 29, 2007 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
341 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
