Question about Dishwashers
Kenmore 665.16529000 When we put the dial to pots and pans the diswasher fills up and cycles through, when the dials moves to normal wash, it fills up and cycles through again. When the dial gets to light wsh we can hear the motor running but nothing is happening, but the soap door opens soon after. The heating light comes on and the inside of the dishwasher gets so hot that it has melted our big plastic tumbler cups on the top rack and makes the counter top extremely hot to the touch. The dial continues to make its way throught the cycle. When we open the door the dishes are still dirty, hot, and there is a pool of soap still on the bottom of the washer.
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 677 Answers
SOURCE: top rack of dishes is not clean
the problem sounds like your water. www.dishwasherfilter.com has an amazing product out that fixes this problem once and for all. it is a small filter that filters the hardminerals out of your water before entering the dishwasher. it is very affordable and guaranteed to work or your money back. you will be amazed how clean your dishes look.
Posted on Aug 11, 2009
  • 45 Answers
SOURCE: dishwasher does not go into the wash cycle
you'll need to determine if the wash motor is running during the wash cycle(listen for noise from the motor). If the motor is not running there is an electrical problem possibly in the motor or the timer. If motor is running but not washing, the pump impellor maybe loose on the motor shaft. The impellor was press fit onto the motor shaft and cannot be retightened. The motor and pump assembly would have to be replaced, somewhat expensive to do.
Posted on Jan 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 431423 won't advance cycle, won't agitate
not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
Jun 11, 2010 | Kenmore 43142 Front Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 70 washer, does not move from one cycle to another
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore Washing Machines
My whirpool quiet wash plus will not completey drain
lets see here you want at least ten bucks to just help me w/ my diswasher problem but if gee i figured it out all by myself i get squat thanks but no thanks.
Aug 28, 2009 | Dishwashers
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
