Question about Maytag Neptune MAH9700 Front Load Washer
Maytag front load washing machine
My machine is level, I have checked that out; but when it spins it vibrates and makes a loud noise.
  • 4 Answers
I have the same machine. You've got to make sure the floor is level, and it's on a HARD surface. Mine is on a pedestal, and on a concrete slab. They spin in such high velocity, that you'll need a solid base. Even the directions say to use a HARD sturdy base. These are very powerful machines, and need to be in the basement, or on a slab.
Posted on Feb 12, 2008
I have the same problem and its making me crazy.
Posted on Feb 05, 2008
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a maytag mah8700aww washer,when it goes into spin,there a loud knocking sound
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer is all over the place when spinning ,sounds loud
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 20, 2011 | Maytag Washing Machines
Washer is very loud during spin cycle. The machine is well balanced and does not rock
heatman101
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stinks terribly and has become so loud you can hardly be in the room when it is on.
Check out this tip I wrote about the noise and vibration thatfront load washers can make..
heatman101
Sep 18, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Makes a loud sound when spinning
heatman101
Sep 08, 2010 | Maytag Neptune Washer
In the final spin the washer is so loud you can't stand by it what is wrong with it
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
