Question about Epson Aculaser C1100 Printer
B door open
I've an Aqulaser C1100, with error message "B door open". I've change the switch but to no avail. Does anyone have any idea how to rectify this issue? Only thing seams to be left is messing with the chip board!!!!
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Posted on Feb 06, 2008
Epson aculaser c1100 b open
Posted on Jun 06, 2011
Epson c1100 e door open
Just solved the same problem. It is a very slight misalignment of the two rollers behind door E. I closed door E holding the vertical bar below the handle and just 'jiggled' it slightly from side to side, and it latched closed. Paper jam fixed, yippee!!
Mar 23, 2013 | Epson Aculaser C1100 Printer
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hello: I have an LG front load Washer Model #WM2010C. Its' receiving a error code (de). I've looked it up and it seems to be "door error." I cannot open the door. When I go to...
You will need a new door llock switch.
to change it you will need to loosen the front bellow by removing clamp, unscrew the twwo scrwes holding the switch then unplug wires to switch and re-install.
Jul 02, 2011 | Washing Machines
Message Paper Jam MP E
The sensor at the back of the printer is either stuk or out of position open the back of the printer and see if there is a little black lever sticking out if so check it for movement if it sticks yuo have to remove the back paper guide and reseat the lever in its correct position
Dec 03, 2008 | Epson Aculaser C1100 Printer
Epsom C1100
cover "B" should be on the back of the printer. when you open the main back door at the bottom there is a little flap that will fall down, this is a sliht design flaw as you have to make sure that this is in an upright position before closing the main back door. from past experience its usualy hit and miss at getting it to work unfortunatly
hope this hepls
Pete
Sep 28, 2008 | Epson Aculaser C1100 Printer
C1100 B Open error
Often, this would just be the sensor falsely thinking that the cover B is still open. You could try checking if the cover is slightly misaligned hence the tab is not triggering the senor/switch. Or try opening and closing and making sure that you hear/feel the latching of the switch.
Better yet, perhaps the parts diagram may be of better help. You would probably be interested likewise in the service manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
May 28, 2008 | HP LaserJet 1018 Printer
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
C door open
Hi , the c door switch try to check might stuck.
Jan 22, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
382 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
