Question about JVC AV-36D503 36" TV
Sound Problem very low sound. Have to crank up the volume above 75% to get any decent sound.
    Problem Solver:
  • 15 Answers
First u must try to plug in scart a dvd or a video.... and see if sound is ok..... if not u have a problem with amplifier or psu... if sound is ok u have a "big" (i said big because it´s harder to find) problem with IF circuit or tuner.... i almost forget u can try tu plug head phones to tv to make some comparations .... sorry my english.....
Posted on Feb 04, 2008
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Is there a sound/volume lock key that may have been hit by mistake........audio and sound in my computer dont see any fault, but have almost no sound
I can help you with your 'almost no sound' computer problem.
The best thing to do when you are not sure what your pc is doing with its sound is to bring up your audio mixer. Do this by right clicking on the volume control icon by the clock on your task bar and selecting 'Open Volume Control', or go through the Control Panel if your taskbar has no volume icon visible.
When looking at your mixer, set Master Volume and Wave mixer bars to about 75%. Now return to whatever application you are using and check where its volume is set. Generally, everything should be set to 75% and then your external speaker volume should be set to a comfortable level.
I hope that helps.
Aug 30, 2010 | Acer NSK8458AN Keyboard
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
Headsets receive no sound
if you have the headphones plugged directly into the audio out, then thats the problem. the audio only supplies a low volume, pre-amplifier output and this needs to be put through an amp of somekind to get a decent volume. Look for a headphone socket on the tv, usually near the s-video plug and coloured green.
May 09, 2010 | Sennheiser RS130 Headset
Asus p5ld2-vm/alc882 sound issue:
Take a sound-cable, and plug the "headphone-output" into the amplifier of your home stereo, and crank-up the volume on your amp.
Otherwise, double-click the volume-control (beside the Windows clock)
to open the "sound-mixer" application. Crank-up all the sliders to maximum, and see if that makes a difference.
Dec 30, 2009 | ASUS P5LD2-VM Motherboard
Low sound at high volume
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 04, 2009 | Sony STR-DG1100 Receiver
Dtv converter box - low sound
I work for Phillips/Magnavox tech support. If the volume is low like that unfortunately, there isn't anything you can do about it. Coby makes a converter box as well as Memorex, and their boxes had the same problems. The box should be returned to the store for an exchange, or sent in for warranty repair/exchange. There is nothing you can do to fix that problem.
I hope this information allows you to make an informed decision as to how to proceed.
Thank you for visiting FixYa.
May 30, 2009 | Philips Magnavox M61117 (DBM61117)
Dell GX280 Dextop: Very Low volume on Headphones
Are these USB headphones? If so, you must install them first and let the Device Manager confirm they are properly installed. Next, go to sound properties in control panel, select the headphones, and crank the volume within Windows. Finally, crank the volume controls on the headphones themselves. If they are not USB headphones, then the same sound jacks that allow speakers to be connected should allow the headphones to work.
Mar 21, 2009 | Dell OptiPlex GX280 PC Desktop
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
JVC AV-36D503 36" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
